Full Version: multiple client on server with multiple cards
Hello,
i'm configuring a server with 4 dvb cards (2 s and 2 t). on the server i plan to connect 2 remote clients.
eEach client connect just fine, but, it seems i can use only one dvb card of the same type at time.
(for example: if on client a i switch to a dvb-s channel, then on client b i can watch the same channel or switch to a channel on the dvb-t cards.. but if i try a different satellite channel, it doesn't work).
Do you guys have some ideas?
Update, i've found that one of the dvb-s (Technisat Skystar USB HD both of them) doesn't have a frontend0 in /dev/dvb/adapterX while the other has....
