2013-09-09, 00:00
ATV2 5.0.1 (4224)
XBMC (12.2 Git:20130502-32b1a5e) Platform: Darwin iOS (11.0.0, Version 5.1.1 (Build 9B206f)). Built on May 2 2013
The log file http://www.filedropper.com/xbmc
Two ATV2 centralized with MySQL server on a NAS QNAP TS-219P+. Managing the MySQL with PhpMyAdmin version 3.3.5 (MySQL version 5.1.36)
Hello to all,
Suddenly today my ATV2 became very unresponsive and slow. When I choose a film or a tv-show it takes 2-3 minutes to go to the next screen. So every click on the remote it takes 2-3 minutes, even if I press to go back. This happens only when messing around with films or tv-shows if I am navigating through add-ons or the menu generally its very responsive and fast.
What I did is to drop the databases (Mymusic and Mivideos) and re create them with no luck. Then I remove all the xbmc from one of my ATV's using ssh and re install it. Drop db's again and re create. At the start everything was perfect but after some time when I was going to view an episode the problem appeared again. If I remove the advancedsettings.xml file (in order to work as stand alone or better without the MySQL) everything is back to normal. I spend the whole day with out any luck.
Thanks in advance!
Mike
Hello to all,
Thanks in advance!
Mike
