2013-09-09, 19:58
I had previously installed the OUYA as an Android APK when it first came out. I have subsequently removed this and am now using the XBMC from the OUYA "store".**
Will this store version automatically be updated when updates come out for it?
**As an aside, I had both installed at the same time at one stage whilst I was testing the OUYA store version. With a particular MP4 I had, it would crash the OUYA store version, but would play fine in the APK version - it would do this consistently even after reboots, etc (ie not just once). This is strange since I assume they were both the same source code.
Thanks,
JB
Thanks,
JB
