H
Hi
I just installed xbmc to a new nexus 7' when play video the audio sound like broken. I have try different setup on audio but no go.
This problem does not happen on my other tablet (Samsung galaxy Tab 2).
Please advise what should I do.
Can you get us a
debug log (wiki) of when this happens?
I had the same problem with my new nexus 7. I saw a suggestion to try one of the nightlies, and found that xbmc-20130802-fd66916-master-armeabi-v7a.apk fixed the audio issue and plays everything.
I've run into a couple of problems with plugins, but nothing showstopping.
The build listed above works for me, but also the Gotham build works.
I do have a problem with one plugin crashing, but everything else seems fine on the Gotham build.
Hi spikey911, what build of XBMC are you trying? I just installed xbmc-20130911-8d2a012-master-armeabi-v7a.apk and found the sound is not working
This is on my new Nexus7 2013. Video looks great but there is no audio.
Cheers,
Iain
Update: The sounds was muted on my device - actually working fine *facepalm*
