Skins Support
Aeon Nox: Silvo
> Which XML for video codec info
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
RockDawg
2013-09-10, 23:26
I am running a version of Aeon Nox 4 that I've customized. I've noticed that the video codec info has lines that overlap making it hard to read. Which XML do I edit to correct this?
mikebzh44
2013-09-11, 08:58
Screenshot.
You can also activate debug by editing addon.xml in Aeon Nox folder and set debuggind option to true :
debugging="true"
When you will run Aeon Nox, XBMC will display current XML file name.
Skins Support
Aeon Nox: Silvo
