2013-09-12, 22:11
UPDATE: Missed a mysql error in the log. Removed all .db files on the ATV2 and restarted it, and now it works again.
My ATV2 is suddently acting weird. Movie and TV Show banners are downloaded from TVDB over and over again. I have verified that the cached thumbnails are generated on the ATV2, and logs says so too. Running XBMC Frodo 12.2.
I did the following procedure to show the problem:
10. Go to TV Shows. All thumbnails are loaded slowly, my http proxy confirms the media is requested from TVDB.
20. Press up on the remote, to go to the bottom of the TV-Shows. Again, banners are requested from TVDB.
30. Press down on the remote, to go to the top of the TV-Shows. All banners are again requested from TVDB.
40. Goto 20.
Log:
http://xbmclogs.com/show.php?id=57939
As an example from the log, we can see it keeps caching the exact same image:
System info/Storage shows /dev/disk0s1s1 (/) has 54% use, and /dev/disk0s1s2 (/private/var) has 30% use.
Not sure when it started, might have taken me a while to notice it. Any idea?
UPDATE:
Oh...
40. Goto 20.
Log:
21:46:32 T:132472832 DEBUG: CurlFile::Open(0x1fd5edc0) http://thetvdb.com/banners/graphical/74372-g.jpg
21:46:33 T:132472832 DEBUG: Caching image 'http://thetvdb.com/banners/graphical/74372-g.jpg' to 'c/ca827b7b.jpg':
21:46:33 T:132472832 DEBUG: cached image 'special://masterprofile/Thumbnails/c/ca827b7b.jpg' size 758x140
21:46:48 T:805064704 DEBUG: CurlFile::Open(0x1fe9cc80) http://thetvdb.com/banners/graphical/74372-g.jpg
21:46:48 T:805064704 DEBUG: Caching image 'http://thetvdb.com/banners/graphical/74372-g.jpg' to 'c/ca827b7b.jpg':
21:46:48 T:805064704 DEBUG: cached image 'special://masterprofile/Thumbnails/c/ca827b7b.jpg' size 758x140
21:47:12 T:805064704 DEBUG: CurlFile::Open(0x1fbda1b0) http://thetvdb.com/banners/graphical/74372-g.jpg
21:47:12 T:805064704 DEBUG: Caching image 'http://thetvdb.com/banners/graphical/74372-g.jpg' to 'c/ca827b7b.jpg':
21:47:12 T:805064704 DEBUG: cached image 'special://masterprofile/Thumbnails/c/ca827b7b.jpg' size 758x140
UPDATE:
Oh...
21:46:18 T:92651520 ERROR: SQL: The database disk image is malformed
Query: PRAGMA cache_size=4096
21:46:18 T:92651520 ERROR: Connect failed with 'SQL: The database disk image is malformed
Query: PRAGMA default_cache_size=4096
21:46:18 T:92651520 ERROR: Unable to create new database
