Full Version: RetroPlayer Test Builds (updated for Nexus)
New Windows and OSX builds posted, I fixed the broken game add-ons. Also, when playing a game, Kodi now samples the controller at that game's framerate (and samples at 60fps when no game is playing)
(2016-02-05, 01:41)lrusak Wrote: [ -> ]New OpenELEC builds posted, quite a few changes. This build should fix all the add-ons being marked as incompatible.
https://github.com/garbear/xbmc/compare/...492af9627d
https://openelec.freestylephenoms.com/retroplayer/
Hi I'm still getting all the emus marked as incompatible, I've tried refreshing the repository just in case but no luck
(2016-02-05, 18:48)flipside101 Wrote: [ -> ]
It should update over time, I forced it by removing the add-ons database and restarting kodi
rm /storage/.kodi/userdata/Database/Addons19.db
systemctl restart kodi
Thank you garbear and lrusak! I was having problems on raspberry pi 2 openelec with the retroplayer repository, but they are solved after updating to the latest ARM version lrusak posted and deleting the addons19.db as suggested. Afterwards I still needed to install manually as per this post, and now everything works great. I'm so excited to see how this project has come to fruition!
I pushed a fix for the broken just-in-time installation failing. It broke in the last rebase to 15.2, but building in-tree was easier that hosting a repo so I never got around to fixing it.
Awesome, I'll do some builds later
New builds uploaded.
This build should fix the just-in-time emulator installation. So instead of installing emulators manually you should be prompted when you try and play a rom that doesn't have a supported emulator installed.
https://github.com/garbear/xbmc/compare/...a000aec446
(2016-02-06, 22:41)lrusak Wrote: [ -> ]New builds uploaded.
Hi @lrusak,
I would love to run and test OpenELEC with retroplayer but I still have a Nvidia ION based HTPC. Would you mind to also build the Nvidia_Legacy version of OpenELEC? I tried to do it myself but I could not figure out how to switch from the default kodi source to the retroplayer branch...
Cheers, glad
(2016-02-08, 11:33)gladiac Wrote: [ -> ]
Hi @lrusak,
Cheers, glad
My Generic build uses my nvidia multi patches so you are able to use it on old hardware.
(2016-02-08, 12:12)lrusak Wrote: [ -> ]
Hi @lrusak,
Cheers, glad
Very cool, thanks!
Hello all, yesterday I tried to play Windjammers on Retroplayer OE but there seems to be no platform specific emulator for it.
I tried MAME - with which I played Passing Shot for 2 hours - but strangely it did not work (works on Openemu, mac).
So I went for BeetleNGP (supposedly "Included in build"), but it was nowhere to be found in the repository Sad
I then installed all the other MAME cores, but neither of them worked.
How can I get it to work?
Windjammers = Best game ever! Wasnt it neo geo though?
yes it is! And yes, best game EVER!
(2016-02-10, 11:25)zag Wrote: [ -> ]Windjammers = Best game ever! Wasnt it neo geo though?
BeetleNGP is a Neo Geo Pocket emu..
Then the core matrix page needs to be updated Smile
