this
(2013-10-16, 14:35)n1md4 Wrote: [ -> ]I've an Onza Razor USB controller, is there a way to get this working automagically with emulators; as yet, without trying very hard, it doesn't work at all...
Additionally, it does arrive in dmesg, but that's about as far as it gets. Is there a general configuration rule for controllers, or should it be working out-the-box.
I have no windows machine, so its unlikely I will be able to provide windows builds in the short term. I'll maybe try and get time to setup a windows VM, but this probably won't happen anytime soon.
(2013-11-29, 17:13)prae5 Wrote: [ -> ]I have no windows machine, so its unlikely I will be able to provide windows builds in the short term. I'll maybe try and get time to setup a windows VM, but this probably won't happen anytime soon.
Probably about time I learn how to build xbmc anyway.
prae5 how did you get around the amd catalyst drivers not downloading peoplerly?
Could you make a OE 3.2.4 Intel 64bit version with retroplayer?
My xbox 360 wired usb controller works out of the box with this version, the OE 3.2.0 version makes my pc crash with the shutdown or restart option with the controller connected + d pad does not seem to work.
Thanks in advance
(2013-11-30, 06:03)brucem Wrote: [ -> ]prae5 how did you get around the amd catalyst drivers not downloading peoplerly?
I already had the drivers, I can upload them somewhere if you want / need them.
Hi!
I'm completely new to retroarch and already got a possibly dumb question: Why isn't there a 3.2.4 build with retroarch?
