(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]After testing on RPi3: (1025 and 1102)
There is also a bug with LiveTV: On switching channels Kodi seems to loose the info, that it is LiveTV. For about a second it doesn't show the LiveTV-Bar (on Estuary). On AeonNox it is the same, but in this second it shows the bar for streams instead.
This does not happen on LE 7.90.x and Milhouse builds.
Sorry it took so long to address this. I don't use LiveTV, only the HDHomeRun plugin which is separate from the PVR api. So I'm not really able to address this... HOWEVER... now that RetroPlayer is in master, you should test the latest nightly based on master. This may still be a problem, but now that it's a problem with master, it's someone else's problem
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]Also I can't get my XB360 controller to work. Kodi says it is configured and when I remove it, it is removed from Kodi.
Did you
Configure your controller?
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]The "loading" animation shows up, even the game is loaded. Should be paused until loading is finished or disable loading animation, when game is started
Not sure exactly what you're saying, but this sounds like an edge case (an error on the edge of loading a game). I'm still focusing on the big picture, like
VFS support and GameStream support, so edge cases will have to wait.
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]Question:
Will there be a games-db, like the one in Films and TVShows?
Yes of course, that was my main motivation for adding games to Kodi. However, Kodi's database code is poor and needs a rewrite. A major refactor has been started, but it will be a while before we see a game library.
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]Suggestions / FR:
1. If only one emulator for a system is installed, then Kodi should automatically use this emulator. If the user wants to use another emulator then there could be a context menu:
Install / manage emulators
Play with another emulator
This used to be the case, but I removed this feature, because ATM it's more important for the user to know which core they're using for reliable bug reports that a minor UX improvement.
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]2. On "stop" ...
...the emulator should "autosave" (even the user has disabled it), so that "resume" is possible". If you played some time without saving and someone hits "Stop" on the remote :~
OR
... the user is aksed "Do you really want to quit?" Yes/no
Autosave used to exist, but I dropped this feature a while ago (I forget why, probably to simplify the RetroPlayer patch to make merging easier due to it being such an immense patch).
(2016-10-31, 10:18)Solo0815 Wrote: [ -> ]I'm really looking forward, when RP is added to Kodi
I'm sure you've seen reports that RetroPlayer has been merged to master, but it is currently disabled until a
bug is fixed and
Savestates are merged. The team has also decided to delay an official announcement until more work and testing has been done and the feature is more polished.
If you want to manually enable games in master, you'll need to
set the "gamesgeneral.enable" setting to true. This can also be done with an advanced setting; i'll document this in the wiki in the near future.
