I have been working on this for days with no luck. There has to be something easy to make this work. I am running Mythbuntu (fresh install from yesterday) that functions perfectly but I cannot get my RaspberryPi XBMC (RaspBMC) to access anything with MythTV. Is there anyone that could please assist... Thanks in advance!!
Version of xbmc or mythtv? Can you connect to the backend from a mythtv frontend? Locally and via network?
debug log (wiki) files for both xbmc and mythbackend.
Thanks for the fast response!
XBMC 12.2
MythTV 2.0.25.2
I can connect to backend with frontend locally. I can access the mytv site url browsing from another computer. I don't have another linux box besides my Raspbmc but I will try and build one quick.
Here is the log from XBMC (
http://xbmclogs.com/show.php?id=58792)... I am not sure where to grab a log file from mythbuntu. Any guidance and I will get it for you.
(2013-09-15, 02:15)jplivingston Wrote: [ -> ]Thanks for the fast response!
XBMC 12.2
MythTV 2.0.25.2
Here is the log from XBMC (http://xbmclogs.com/show.php?id=58792)... I am not sure where to grab a log file from mythbuntu. Any guidance and I will get it for you.
I just Installed MythTV on a windows machine quickly and it automatically found the backend and filled in all the settings and worked.
What address do you use to access mythweb?
Ip address correct, looks like it can connect:
00:04:58 T:2825909312 ERROR: AddOnLog: MythTV cmyth PVR Client: Failed to connect to MythTV backend on 192.165.1.186:6543
00:04:58 T:2825909312 ERROR: AddOnLog: MythTV cmyth PVR Client: Failed to connect to backend
I just rebooted my mythTV box and I am now connected! Only problem now is that every channel responds as not available...
I am going to try and sort through the new log to see if i can figure that out now.
thanks for all your help so far!`
