Full Version: XBMC crashes on start up after CCC upgrade
Hi, first of a few details... Running Win 7 (64) with a Radeon HD 6400 graphics chip, on Frodo 12.2.
I was using the AMD CCC 12.10 with no problems, when I stupidly decided to follow the prompt to upgrade it to 13.4. After this XMBC became really sluggish on the menus (but played files ok). I the uninstalled the CCC and XBMC just crashes as soon as I start it. I've tried putting CCC 12.10 back on, but it's still the same. CCC was also reporting a failure to start, but I've set that to compatibility mode, and it works ok now. Any ideas please?
I can paste the log file, but it doesn't say much...
edit: neither vlc or media player work, so it's clearly not an xbmc fault.
edit: fixed now, after lots of messing around. Please delete the thread. thanks
I'm using 13.1 and don;'t have any real issues, but have had with some versions, if it's not broken don't fix it comes to mind.
Driver Packaging Version 9.012-121219a-152192C-ATI
Catalyst Version 13.1
Provider Advanced Micro Devices, Inc.
2D Driver Version 8.01.01.1278
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet002/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 9.14.10.0945
OpenGL Version 6.14.10.12002
Catalyst Control Center Version 2012.1219.1521.27485
I run XBMC with hardware gfx acceleration
(2013-09-17, 20:41)willp2003 Wrote: [ -> ]Hi, first of a few details... Running Win 7 (64) with a Radeon HD 6400 graphics chip, on Frodo 12.2.
What was the solution?
