2014-03-09, 23:24
2014-03-10, 23:27
2014-03-11, 01:14
EDIT: Issue appears to be related to XBMC install and not Ace. Sorry!
2014-03-12, 16:31
(2014-03-08, 16:35)Axel Foley Wrote: [ -> ]Two issues:
1. The skin is missing the new options layout of XBMC. You cannot set "Beginners/Intermediate/Advanced" in the main settings menu. I had to switch to Confluence, set Advanced, then switched back to Ace in order to see ALL the options.
2. The Extrapack download never completes, I reach 97-98-99% and then it exits saying the download failed. It did this also in Frodo.
Great skin...my favorite...
Yeah, I am having exactly the same problem with the Extrapack failing to download after 99% using the xunity-mod release.
2014-03-17, 15:15
Hi there,
Gotham Beta 2 and Ace 6.0.2 - I can't see options in the Artwork Downloader settings. Had to use Confluence to change it. Maybe it's a known issue?
2014-03-17, 16:07
@upD8R, yes need fixes for work fine, press down arrow many times for see items, changes in XBMC gotham broken skin and addons settings in a few places. For now, MarcosQui, fixed this trouble only in Aeon MQ5 (gotham version only).
2014-03-18, 21:22
Thanks for the response, Wanilton.
2014-03-23, 00:29
Awesome skin, but dll link doesnt work.. okay found It. But ts link doesnt work.
2014-03-28, 23:44
hey,
i need a media flag for the aspect ratio "2.40:1". How can I add it?
2014-03-28, 23:51
@dirtydesaster, go to userdata/addons/skin ace
open media folder and create 2 more folders
skin.ace\media\flags\aspectratio
Put image with aspect ratio "2.40:1" in aspectratio folder and done.
2014-03-29, 00:24
mh ok that's easy
but, where can I get a flag with the same style as the other ones?
2014-03-31, 03:28
When playing music with a visualization, is there a way to have the artist info brought up on demand? I can see how to turn it on or off but I'd like to be able to bring up for a moment without interrupting the visualization.
2014-04-05, 21:43
(2014-03-31, 03:28)macbean Wrote: [ -> ]When playing music with a visualization, is there a way to have the artist info brought up on demand? I can see how to turn it on or off but I'd like to be able to bring up for a moment without interrupting the visualization.
Continuing with this, is there a way, while listen to music and having a visualization (Project M) that an info screen appears for a couple of seconds to show the information of the song and after that time disappears?
Great work!!
2014-04-10, 03:10
edit: nevermind wrong thread
2014-04-13, 07:15
It's this thread dead?
