TVtunes v4.4.3 appears to hang XBMC for 8-10 minutes when entering the video information view for a Movie. This particular movie is stored as VIDEO_TS files. There is not a theme song on my disk for this movie.
Here is my XBMC setup.
OpenElec 4.0.1 which uses Gotham 13.1 beta 1
Old HP SFF AMD socket 939 3500+ processor with Nvidia/ASUS GT610 video card
Confluence skin with TVtunes enabled in the skin
My movies are on a samba share to a server:
HP Proliant MicroServer
Windows Server 2011
Movies are stored on a disk shared with SAMBA. One movie per directory. DVDs are stored under VIDEO_TS directory within movie directory
I can view the list of movies without problem, but when I select a movie the video information is shown and "Working" with the spinning circle appears. The system is then unresponsive. Although the screen will dim due to the screen saver, and my IR receiver will light up when buttons are pressed on the remote, XMBC appears to be stuck. No button presses other than the power button have an effect.
Here is the
log file
Strangely, this only occurs when I show the video information for a movie stored as VIDEO_TS files. No hang is observed when showing the information for a movie stored as an mkv file.
If I turn TVTunes off in the setting in the Confluence skin, no hang is observed.
When I switch to xperience1080++, the hang occurs when I try to play the VIDEO_TS movie rather than when the video information is first shown. The screen changes from the DVD info screen to the Movie Wall, and the red busy indicator appears. The DVD does not play, or show the DVD menu for about 10 minutes. As with the Confluence skin, no problem is seen with movies stored as an mkv file.
This is the same system that I reported the issue with the videoExtras database. I am not using a customDir for the tvtunes though. Your first guess may be that I have a corrupted setup, but I have wiped XBMC and re-installed openElec and the situation does not change.
Here is the tvtunes settings.xml
<settings>
<setting id="custom_path" value="" />
<setting id="custom_path_enable" value="false" />
<setting id="delayStart" value="0" />
<setting id="downvolume" value="14" />
<setting id="endafter" value="2" />
<setting id="exact_match" value="false" />
<setting id="fadeIn" value="false" />
<setting id="fadeOut" value="false" />
<setting id="flac" value="false" />
<setting id="logEnabled" value="true" />
<setting id="loop" value="false" />
<setting id="m4a" value="false" />
<setting id="movielist" value="false" />
<setting id="mp3" value="true" />
<setting id="multiThemeDownload" value="false" />
<setting id="musicvideolist" value="false" />
<setting id="random" value="false" />
<setting id="searchMovieDownload" value="false" />
<setting id="searchSubDir" value="false" />
<setting id="showVideoInfoButton" value="true" />
<setting id="shuffle" value="false" />
<setting id="smb_login" value="Iris" />
<setting id="smb_psw" value="xxxxxxx" />
<setting id="smb_share" value="false" />
<setting id="subDirName" value="Themes" />
<setting id="themeSearchSource" value="televisiontunes.com" />
<setting id="trackLengthLimit" value="20" />
<setting id="tvlist" value="true" />
<setting id="wav" value="true" />
<setting id="wma" value="false" />
</settings>
