Full Version: Mediaportal and android
Hi all,
My first post here so be gentle:p
I will first describe what i have, then my problem hope you guys can help me out. Because i searched the internet and this forum now for days...
I have a tv server with media portal installed, also a HTPC with windows 8 and ofcourse xbmc. On the htpc live tv is working like a charm. Since about a week now i own a minix neo x5 with android 4.1.1. And installed on this xbmc 12.2 frodo.
The problem is i tried to install live tv but it won't start up. I used the same settings as on my htpc.
- tried using ffmpeg in the client, no go. Will try to load the channel(ned1) but after 2 seconds it will stop and just show the channel list
- same thing happens when i choose tsreader without rtsp streaming set on true.
However on my htpc rtsp streaming is set on true and works. On the minix when i set it on true i get an error saying that the client doesn't support rtsp.
My xbmc build on the htpc is compiled: may 6 2013. On the minix may 2 2013.
There is no build that i can find that will work on the minix. Tried to use a nightly build or a monthly build. Still no go.
I hope you guys van help me out because it's starting to get a little frustrating. :p
Thanks in advance.
