Hello xbmc community!
First I just wanted to say thank you for all of your guys hard work and help without it we wouldn't be enjoying all this great stuff
I'm a big fan of everything you all have accomplished.
Ok now on to my issue, Running ATV2 with tethered boot 5.2.1 software (I know it's a friends and he already had it updated to it
running xbmc 12.2 Git:20130502-32b1a5e (compiled May 2 2013)
log files are here:
http://xbmclogs.com/show.php?id=60178
http://xbmclogs.com/show.php?id=60177
during playback either using Icefilms or streaming off the network it keeps closing out of xbmc altogether or delays and hangs up. I know it could be running smoother as I've seen
it run way better than mine. so just want to get it working flawlessly if possible.
I saw that Icefilms meta data issue looks to be fixed so that's a separate issue that I'll have to work on..
any and all help is greatly appreciated!
Sparky
Get rid of Icefilms and try again to see if problem persists. By the way, we do not provide support for piracy add-ons per
forum rules (wiki).
Disable LCD support in settings (you don't have one for sure!)
22:35:49 T:124592128 ERROR: SQL: The database disk image is malformed
Query: PRAGMA cache_size=4096
22:35:49 T:124592128 ERROR: Connect failed with 'SQL: The database disk image is malformed
Query: PRAGMA default_cache_size=4096
22:35:49 T:124592128 ERROR: Unable to create new database
One of your databases is corrupted (not sure which one). Also no icefilms support go ask the author for problems...
(2013-09-19, 08:37)artrafael Wrote: [ -> ]Get rid of Icefilms and try again to see if problem persists. By the way, we do not provide support for piracy add-ons per forum rules (wiki).
ah ok thanks...hmm it does it while streaming off my laptop computer from the network as well...not just that addon thanks for the feedback
(2013-09-19, 09:30)Memphiz Wrote: [ -> ]Disable LCD support in settings (you don't have one for sure!)
Memphiz I'm connected to 50" LCD TV does that not count as LCD? LOL oh wait unless you're talking about a small LCD Display like on a dvd player?
ah ok thanks for the feedback I have posted on the author's forum...
lcd in xbmc means ... small text only displays ... and this setting is turned on on your setup somehow (clicking buttons you don't understand hhehehe??
(2013-09-19, 20:26)Memphiz Wrote: [ -> ]lcd in xbmc means ... small text only displays ... and this setting is turned on on your setup somehow (clicking buttons you don't understand hhehehe?? )
Ahhhhh ok I've turned it off thanks a ton
here is a new log file for streaming from my laptop which it stopped and then closed out of the movie back to XBMC
http://xbmclogs.com/show.php?id=60428
something I've notice is that mkv files are the ones i seem to have issues with avi or mp4 are okay hope that detail helps? :-)
Fresh reboot of the box and here is newest log for playing
http://xbmclogs.com/show.php?id=60876
is this a network issue or possibly doing to much at once? the library was updating movie info
17:42:56 T:154394624 WARNING: FillBuffer: curl failed with code 22
17:42:56 T:154394624 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
17:42:56 T:154394624 ERROR: Run: Unable to parse web site
17:43:17 T:152522752 ERROR: Open - Error, could not open file smb://KYLE-LAPTOP/movies/Jobs.2013.720p.HDRip.XviD.AC3-RARBG.avi
17:43:17 T:152522752 ERROR: OpenDemuxStream - Error creating demuxer
(2013-09-19, 22:18)sparkyATV2 Wrote: [ -> ] (2013-09-19, 22:09)Memphiz Wrote: [ -> ]from http://wiki.xbmc.org/index.php?title=XBM...ns.2Ffixes
try disable the extraction of thumbnails
Ok did so, just an update .mp4 and .mkv files both have issues...especially when FFwd to get back to a spot after it dumps, and I've cleared the cache.
Thanks again Memphiz
here is another log while trying to watch from laptop. http://xbmclogs.com/show.php?id=60516
This one kicked me all the way out of XBMC http://xbmclogs.com/show.php?id=60523
hope these logs help.
