Greetings. I followed a youtube video and installed NextPVR client. It seems to have installed correctly, but I am getting a connection lost error message. When I went to the configure tab, it already had an ip address of 127.0.0.1 The port was 8866, and the pincode was 0000. I hit ok but i am getting the error message. Can somebody tell me what I am doing wrong.
Is NextPVR on the same machine as your XBMC?
I am having the same issue. According to the information provided here,
http://www.gbpvr.com/nwiki/pmwiki.php?n=...alledParts , you need to adjust your firewall settings to allow the program. The issue I am having is that that the file folder is empty. Any help would be greatly appreciated. Thank you.
What files folder? Do you mean "C:\Program Files\NPVR" ("C:\Program Files (x86)\NPVR" on 64bit windows)? If this is empty, then it sounds like you haven't install NextPVR, or you've installed it elsewhere.
