2013-09-20, 18:57
These are the changes that have been done to 13.0 Gotham till now.
Updated PyDocs can be found here:
http://mirrors.xbmc.org/docs/python-docs/
Quote: /**
* onDatabaseScanStarted(database) -- onDatabaseScanStarted method.
* database - video/music as string
* Will be called when database update starts and return video or music to indicate which DB is being updated
Quote: /**
* addSortMethod(handle, sortMethod, label2Mask) -- Adds a sorting method for the media list.
* handle : integer - handle the plugin was started with.
* sortMethod : integer - number for sortmethod see SortFileItem.h.
* label2Mask : [opt] string - the label mask to use for the second label. Defaults to '%D'
* applies to: SORT_METHOD_NONE, SORT_METHOD_UNSORTED, SORT_METHOD_VIDEO_TITLE,
* SORT_METHOD_TRACKNUM, SORT_METHOD_FILE, SORT_METHOD_TITLE,
* SORT_METHOD_TITLE_IGNORE_THE, SORT_METHOD_LABEL,
* SORT_METHOD_LABEL_IGNORE_THE, SORT_METHOD_VIDEO_SORT_TITLE,
* SORT_METHOD_VIDEO_SORT_TITLE_IGNORE_THE, SORT_METHOD_FULLPATH,
* SORT_METHOD_LABEL_IGNORE_FOLDERS, SORT_METHOD_CHANNEL
* example:
* - xbmcplugin.addSortMethod(int(sys.argv[1]), 1)
Quote: /**
* removeItem(index) -- Remove an item by index number.
* index : integer - index number of the item to remove.
* example:
* - cList.removeItem(12)
Quote: /**
* create(heading[, message]) -- Create and show a background progress dialog.\n
*\n
* heading : string or unicode - dialog heading\n
* message : [opt] string or unicode - message text\n
*\n
* *Note, 'heading' is used for the dialog's id. Use a unique heading.\n
* Use update() to update heading, message and progressbar.\n
*\n
* example:\n
* - pDialog = xbmcgui.DialogProgressBG()\n
* - pDialog.create('Movie Trailers', 'Downloading Monsters Inc. ...')\n
* update([percent, heading, message]) -- Updates the background progress dialog.\n
*\n
* percent : [opt] integer - percent complete. (0:100)\n
* heading : [opt] string or unicode - dialog heading\n
*\n
* *Note, To clear heading or message, you must pass a blank character.\n
*\n
* example:\n
* - pDialog.update(25, message='Downloading Finding Nemo ...')\n
* close() -- Close the background progress dialog\n
*\n
* example:\n
* - pDialog.close()\n
* isFinished() -- Returns True if the background dialog is active.\n
*\n
* example:\n
* - if (pDialog.isFinished()): return\n
Quote: /**
* exists(path)
* path : file or folder (folder must end with slash or backslash)
* example:
* success = xbmcvfs.exists(path)
Quote: /**
* yesno(heading, line1[, line2, line3]) -- Show a dialog 'YES/NO'.
* heading : string or unicode - dialog heading.
* line1 : string or unicode - line #1 text.
* line2 : [opt] string or unicode - line #2 text.
* line3 : [opt] string or unicode - line #3 text.
* nolabel : [opt] label to put on the no button.
* yeslabel : [opt] label to put on the yes button.
* autoclose : [opt] integer - milliseconds to autoclose dialog. (default=do not autoclose)
* *Note, Returns True if 'Yes' was pressed, else False.
* example:
* - dialog = xbmcgui.Dialog()
* - ret = dialog.yesno('XBMC', 'Do you want to exit this script?')\n
Quote: /**
* convertLanguage(language, format) -- Returns the given language converted to the given format as a string.
* language: string either as name in English, two letter code (ISO 639-1), or three letter code (ISO 639-2/T(B)
* format: format of the returned language string
* xbmc.ISO_639_1: two letter code as defined in ISO 639-1
* xbmc.ISO_639_2: three letter code as defined in ISO 639-2/T or ISO 639-2/B
* xbmc.ENGLISH_NAME: full language name in English (default)
* example:
* - language = xbmc.convertLanguage(English, xbmc.ISO_639_2)
Quote: /**
* notification(heading, message[, icon, time]) -- Show a Notification alert.
* heading : string - dialog heading.
* message : string - dialog message.
* icon : [opt] string - icon to use. (default xbmcgui.NOTIFICATION_INFO)
* time : [opt] integer - time in milliseconds (default 5000)
* Builtin Icons:
* xbmcgui.NOTIFICATION_INFO
* xbmcgui.NOTIFICATION_WARNING
* xbmcgui.NOTIFICATION_ERROR
* example:
* - dialog.notification('Movie Trailers', 'Finding Nemo download finished.', xbmcgui.NOTIFICATION_INFO, 5000)\n
Quote: /**
* notification(heading, message[, icon, time, sound]) -- Show a Notification alert.
* sound : [opt] bool - play notification sound (default True)
* Builtin Icons:
* example:
Quote: /**
* input(heading[, default, type, option, autoclose]) -- Show an Input dialog.
* default : [opt] string - default value. (default=empty string)
* type : [opt] integer - the type of keyboard dialog. (default=xbmcgui.INPUT_ALPHANUM)
* option : [opt] integer - option for the dialog. (see Options below)
* Types:
* xbmcgui.INPUT_ALPHANUM (standard keyboard)
* xbmcgui.INPUT_NUMERIC (format: #)
* xbmcgui.INPUT_DATE (format: DD/MM/YYYY)
* xbmcgui.INPUT_TIME (format: HH:MM)
* xbmcgui.INPUT_IPADDRESS (format: #.#.#.#)
* xbmcgui.INPUT_PASSWORD (return md5 hash of input, input is masked)
* Options Password Dialog:
* xbmcgui.PASSWORD_VERIFY (verifies an existing (default) md5 hashed password)
* Options Alphanum Dialog:
* xbmcgui.ALPHANUM_HIDE_INPUT (masks input)
* *Note, Returns the entered data as a string.
* Returns an empty string if dialog was canceled.
* example:
* - d = dialog.input('Enter secret code', type=xbmcgui.INPUT_ALPHANUM, option=xbmcgui.ALPHANUM_HIDE_INPUT)\n
Quote: /**
* onNotification(sender, method, data) -- onNotification method.
* sender - sender of the notification
* method - name of the notification
* data - JSON-encoded data of the notification
* Will be called when XBMC receives or sends a notification
<label>$LOCALIZE[SCRIPTXXX]</label>
<label>$ADDON[<script_id> <string_id>]</label>
<label>$ADDON[script.tvguide 30007]</label>
Quote: /**
* play([item, listitem, windowed, startpos]) -- Play this item.
* item : [opt] string - filename, url or playlist.
* listitem : [opt] listitem - used with setInfo() to set different infolabels.
* windowed : [opt] bool - true=play video windowed, false=play users preference.(default)
* startpos : [opt] int - starting position when playing a playlist. Default = -1
* *Note, If item is not given then the Player will try to play the current item
* in the current playlist.
* You can use the above as keywords for arguments and skip certain optional arguments.
* Once you use a keyword, all following arguments require the keyword.
* example:
* - listitem = xbmcgui.ListItem('Ironman')
* - listitem.setInfo('video', {'Title': 'Ironman', 'Genre': 'Science Fiction'})
* - xbmc.Player().play(url, listitem, windowed)
* - xbmc.Player().play(playlist, listitem, windowed, startpos)
