Full Version: Music no longer scanning into library
Since the last big update to retroplayer I can no longer scan music into my library. I have tried removing the library and letting XBM make a new one from scratch and I cannot get anything to populate into it. I have tried several scrapers. I have removed the source and readded it. I have debugging turned on and there are no errors, this is all that is logged:
09:06:53 T:2925525824   DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "AudioLibrary.GetAlbums", "params": {"properties": ["title", "description", "albumlabel", "theme", "mood", "style", "type", "artist", "genre", "year", "thumbnail", "fanart", "rating", "playcount"], "limits": {"end": 20}, "sort": {"order": "descending", "method": "playcount" }}}
09:06:53 T:2925525824   DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview  WHERE albumview.strAlbum <> ''
09:06:53 T:2925525824   DEBUG: GetAlbumsByWhere - query took 1 ms
09:06:53 T:2925525824   DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "AudioLibrary.GetAlbums", "params": {"properties": ["title", "description", "albumlabel", "theme", "mood", "style", "type", "artist", "genre", "year", "thumbnail", "fanart", "rating", "playcount"], "limits": {"end": 20}, "sort": {"order": "descending", "method": "dateadded" }}}
09:06:53 T:2925525824   DEBUG: GetAlbumsByWhere - query took 0 ms
09:20:52 T:3037521664   DEBUG: OnKey: launch_media_center (0xc3) pressed, action is Info
09:20:52 T:3037521664   DEBUG: CGUIMediaWindow::GetDirectory (/storage/Music/The Airborne Toxic Event/The Airborne Toxic Event (Bonus Track Version)/)
09:20:52 T:3037521664   DEBUG:   ParentPath = [/storage/Music/The Airborne Toxic Event/]
09:20:52 T:3037521664   DEBUG: DialogProgress::StartModal called
09:20:52 T:3037521664   DEBUG: ------ Window Init (DialogProgress.xml) ------
09:20:52 T:3037521664   DEBUG: Window DialogProgress.xml was already loaded
09:20:52 T:3037521664   DEBUG: Alloc resources: 0.06m
09:20:52 T:3037521664   DEBUG: LoadMusicTag: loading tag information for file: /storage/Music/The Airborne Toxic Event/The Airborne Toxic Event (Bonus Track Version)/11 The Winning Side (Bonus Track).m4a
09:20:52 T:3037521664   DEBUG: DialogProgress::StartModal called (already running)!
09:20:52 T:3037521664   DEBUG: Alloc resources: 0.03m
09:20:53 T:3037521664   DEBUG: LIRC: Update - NEW at 3669691:000000037ff07bf0 00 More_UP mceusb (More_UP)
09:20:53 T:3037521664   DEBUG: ------ Window Init (DialogOK.xml) ------
09:20:53 T:3037521664   DEBUG: Window DialogOK.xml was already loaded
09:20:53 T:3037521664   DEBUG: Alloc resources: 0.03m
09:20:54 T:3037521664   DEBUG: LIRC: Update - NEW at 3671475:000000037ff07bdd 00 Enter mceusb (Enter)
09:20:54 T:3037521664   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
Is anyone else experiencing this issue?
I may have it fixed
does the issue also occur in the official Gotham Alpha 7?
It does in official and retroplayer. This whole issue started because my music library quit updating. So I nuked my old database and let XBMC create a new one. For whatever reason XBMC would not add anything in the existing source to the database so I removed the source and re-added it. At his point the music still would not scan into the library when I updated it, but when I chose scan into library on the root of my music it brought everything in. But now I am back to the original issue that the library still does not update, and if I try to refresh the information on an existing album or artist it fails.
