Does anyone know of a program that can download subtitles
en masse? I'd like something I could point at my movie folder and have it download missing subtitles, hopefully something that can figure out which subtitle version fits my movie file. I get dirty looks from the family when we play "pick the subtitle" lotto on XBMC.
Hi.
Your post is old, but if you haven't found yet, you can try periscope (
https://github.com/patrickdessalle/periscope)
You can also take a look at periscope-daemon (periscope
d), a script I built hover periscope which does the same thing, but as a daemon with inotify support (linux only)
https://github.com/jcsaaddupuy/periscoped
When a sub is not found, periscoped will retry again and again, but with an increasing laps of time - so video with no sub at all will be less and less processed.
Thanks! Your python script and periscope look perfect! Quick question: if I import a path, will your script also check for new files added to the path or do I need to re-import manually?
