Full Version: Crashing after upgrading to Win 7 64 bit
Hi
I've been using ATV2's for a over a year now without any issues. I have just upgraded my PC Windows 7 64 bit and now my ATV's crash out of XBMC.
I tried removing XBMC and re-installing. XBMC is fine, doesn't crash until I create a source (link) to my movie files on my PC. I can safely rule out a problem with the ATV itself as my 2nd one in the bedroom is doing the same thing.
Are there any known issues with Win 7 64 bit?
I've fixed it. I recently added a new movie after my uograde and this is what's causing it to crash. After adding movies for over a year without a problem I couldn't see that as being the error. The movie plays fine on my PC. No idea why a movie would cause xbmc to crash but there you go.
Did you try playing the movie with XBMC on your PC, or another player? If you have the movie file still, it might be of interest to our developers.
I've just tried it in XBMC on my PC and it plays ok. I didn't add it to my movie list though so may it have something to do with the scraper?
Here are the details of the file anyway:
General
Complete name :Stuck In Love\Stuck In Love.mkv
Format : Matroska
Format version : Version 2
File size : 4.37 GiB
Duration : 1h 36mn
Overall bit rate mode : Variable
Overall bit rate : 6 465 Kbps
Encoded date : UTC 2013-09-19 00:34:10
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Attachment : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 36mn
Bit rate : 5 632 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.255
Stream size : 3.81 GiB (87%)
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 36mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 443 MiB (10%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 1h 36mn
Bit rate mode : Variable
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Stream size : 44.3 MiB (1%)
Writing library : aoTuV 20110424 (UTC 2011-04-24)
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:07:22.275 : en:00:07:22.275
00:16:54.305 : en:00:16:54.305
00:26:52.694 : en:00:26:52.694
00:34:54.968 : en:00:34:54.968
00:41:26.859 : en:00:41:26.859
00:50:32.196 : en:00:50:32.196
00:57:48.632 : en:00:57:48.632
01:08:03.663 : en:01:08:03.663
01:15:57.303 : en:01:15:57.303
01:25:54.608 : en:01:25:54.608
01:32:44.684 : en:01:32:44.684
