I installed XBMC on my droid razr and was trying to use the free cable plug-in to watch the daily show. When I went to to the full episodes a script error occurred. I'm attaching the log of it. Any suggestions ones have would be appreciated.
Part of the log file follows:
(MOD EDIT: Remove log contents pasted directly in post)
Welcome to the XBMC forums.
Which version of the FreeCable add-on are your using?
The original BlueCop version here:
http://forum.xbmc.org/showthread.php?tid=101938
or the updated version by moneymaker here?
http://forum.xbmc.org/showthread.php?tid=166099
If you're using the former, try the latter instead. If you're already using the latter, try posting to that thread instead as it's monitored by moneymaker, the author/maintainer of the updated add-on.
Also, please don't paste log contents (especially snippets) directly in a post. Instead, please upload the entire
debug log (wiki) contents to a public paste site such as
www.xbmclogs.com and post the assigned URL here.
Thank you very much for the reply. I had the original BlueCop version installed. I followed the directions to install the moneymaker version and it worked great. If I have any further issues I'll follow the log rules.
