2013-09-26, 14:34
G-Box Midnight MX2 iPhone remote for XBMC not working
I used the iPhone app from the apple app store. My iPhone XBMC remote used to work with the Raspberry Pi but I cannot get this to work with G-Box Midnight MX2. I have tried it at various family locations and different routers but it just doesn't work. I know its not a problem with router because remote use to work for Rasperry PI.
I did go into settings, and enable the same items that I did with the Raspberry.Webserver; enabled, Remote control; enabled, AirPlay; enabled;
Under System, I have Internet Access enabled to use HTTP proxyserver to access the internet enabled. Input Devices is enabled mouse and touch screen support.
Am I missing something? or maybe, the app is not compatible with the Android box?
Jason
Jason
