2013-09-26, 20:06
I am using RaspBMC.
I found essentially every tutorial out there on getting a PS3 BD remote working on RaspBMC. I managed to sync the newer model of the remote (which has a different Bluetooth chipset) by manually using the bluez utilities (I'll elaborate more on this later). If I do a, it shows "PS3 Remote Controller". If I do , every button I press on the controller appears as an event in the terminal.
However, none of this is represented in the xbmc log, even with debug logging enabled.
I added the following to /home/pi/.xbma/userdata/keymaps/test.xml:
The notification message doesn't appear on screen or in the xbmc log, even though there is no failure message in the log. The behavior is the same even when that code is in keyboard.xml. Pressing the left key shows the key ID of 105 in the event test, but has no effect on XBMC proper.
I also have a bluetooth.conf in /etc/bluetooth/input.conf as specified in http://wiki.xbmc.org/index.php?title=HOW..._BD_Remote, but that doesn't seem to help things at all. Toggling the "remote sends keyboard input" setting doesn't have an effect.
cat /proc/bus/input/devices | grep emot
evtest /dev/input/ps3
<keymap>
<global>
<joystick name="PS3 Remote Controller">
<button id="105">Left(Successful,Mapping,10</button>
</joystick>
</global>
</keymap>
