tential, this is very different in relation skin ACE:
REPLACE MENU
Right now you can forget everything that you ever saw about main menu customization.
In Aeon MQ 5 the new resource REPLACE do not only do the reorganization of the items but also do it as a complete integration betwen menu and submenu.
You can change any item of your submenu directly to the main menu or the reverse operation, this is the dream of any user.
The reorder as it is know on Aeon MQ 4 is also available. However is much better and simpler to use.
CLONE SUBMENU
Besides being able to reorganize the submenu in however way you like, you can also personalize this submenu with the items that you want or then clone other items in any other submenu.
Create a Playlist menu and clone the Movies submenu in just a few seconds, all very simple and effective.
SUBMENU AND MORE SUBMENUS
The Aeon MQ 5 holds all the submenus in an individual way, the total number of supported submenus is bigger than 2400 itens!
Each menu has its own set of submenus, some menus allow up to 20 customizable submenus.
MAIN MENU PRESETS
Organize the main menu the way you wish, then save these settings as a preset. Reorder the main menu for your wife or your kids and save it as another preset.
You can also arrange a menu fully optimized for video, one for music and so on, you can have up to 10 presets independently of each other.
So with just two clicks you can switch between the pre-saved settings, very fast and convenient.
REORDER MENU
A resource from Aeon MQ 4, now even more powerful and easier to use. You can create a totally customized menu of your personal way.
Which menu do you want to put as the main focus? Movies, Series, or any other? In Aeon MQ 5 you can do whatever you want.
MY MENU 1 and MENU 2
Now you have got the double of items to customize, every My Menu supports a total of 12 items.
Dozens of menus scattered around? Not anymore!
Concentrate all your Playlists or emulators in a single list.
Have others things, it´s not equal, Ace is a great skin, more light and good in customization too, but MQ5 is much more powerfull.
