That did it! Thanks. For the record I am using windows 7 and XBMC 13.
For my next question, I would like to use the TV Shows "Background Image use collection Fanarts" for a video playlist. Is there anyway to do this. My thought was to use the multiple image background and map it to the correct location, but once again I don't know where that location is. Thanks again for the quick response on my previous question. Also, I am relatively new at this, how do I add reputation to someone?
is the extended info script .50 for gotham working for anyone after the stable release of xbmc 13
(2014-05-08, 04:52)cgebke Wrote: [ -> ]That did it! Thanks. For the record I am using windows 7 and XBMC 13.
You can’t use the ‘collection’ feature with video playlist’s in MQ5.
If you want to use any folders created by artwork organizer though, I believe the default path is XBMC\userdata\addon_data\script.artworkdownloader.
Hi
Currently, I'm using the multiplex view (in the movie section). However, it takes really long (I think ~3-4 seconds) that the extend info (movie description, ...) shows up - can I change this value or is my hardware not powerful enough? Thx
Regards
Yu
Yes. You can customise this on the top menu in you mobie library.
Keep pressing up.
Yesterday I updated to Gotham, and then noticed that the MQ5 skin was available, having previously been using Frodo with MQ4. However, when I try and install it from the official repo I get the "Dependencies not met" error.
After a bit of research I discovered that I needed to install the "manual installs" listed on page 1 first and then install the skin. So I set about doing this, all of which was going great until I tried to install the "Library Editor Script". This is now the only "Manual Install" that I have left.
I could not find it on the official repository, so I have downloaded the ZIP file and choose to "Install from ZIP", but nothing happens, the file does not install but I don't get any error message.
I downloaded the ZIP from the official source here:
https://github.com/phil65/script.libraryeditor
What am I doing wrong? I really want to use the MQ5 skin.
Easiest thing to do is to manually download the MQ5 zip. Extract it, and place the folder in the add-ons folder.
(2014-05-08, 15:16)Samu-rai Wrote: [ -> ]Easiest thing to do is to manually download the MQ5 zip. Extract it, and place the folder in the add-ons folder.
Would it not then be missing the "Library Editor Script" though, therefore losing some features?
Also, where would I download the MQ5 ZIP file from? It is not listed on MarcusQui's webpage.
(2014-05-08, 15:33)foster1984 Wrote: [ -> ]Would it not then be missing the "Library Editor Script" though, therefore losing some features?
If you want to install "Library Editor Script" than you can easily clone the reporsitory (git clone
https://github.com/phil65/script.libraryeditor.git) into your addon folder.
(2014-05-08, 15:44)Yu Tendo Wrote: [ -> ] (2014-05-08, 15:33)foster1984 Wrote: [ -> ]Would it not then be missing the "Library Editor Script" though, therefore losing some features?
If you want to install "Library Editor Script" than you can easily clone the reporsitory (git clone https://github.com/phil65/script.libraryeditor.git) into your addon folder.
I have already tried extracting the ZIP files and placing into the AddOns folder (Though perhaps I was putting them in wrong place), using the ZIP file I linked off to.
Also, that link just goes to a 404 error page. Unless again, I am just being dense.
(2014-05-08, 15:44)Wanilton Wrote: [ -> ]Here Gotham Version - Skin Aeon MQ5:
http://mirrors.xbmc.org/addons/gotham/sk...-6.0.2.zip
I will try this when I get home this evening.
Do I extract the folder, and if so where should I place it?
(2014-05-08, 16:06)Wanilton Wrote: [ -> ]Get script extended info here (gotham release), my fix, work fine for me:
http://www.files.xbmcbrasil.net/scriptex...edinfo.zip
Extract MQ5, if you use windows in
users/yourname/appdata/roaming/xbmc/addons
Ok, will extract the skin ZIP file later and place it there. Will that also install the "automatic installs" listed on page 1?
I have managed to install the extended info script via a ZIP. Im struggling with the Library editor script.
