iceman600, don´t appear more item (hidden)...
(2014-07-26, 23:19)Wanilton Wrote: [ -> ]@iceman600, don´t appear more item (hidden)...
I know but the previous question is how to change the blank photo on the main library.
(2014-07-26, 23:04)lja2014 Wrote: [ -> ] (2014-07-26, 22:48)Wanilton Wrote: [ -> ]@lja2014, yes, it´s for you go to parent folder, it´s exist in all skins.
XBMC have hidden option if you desire, work if you use remote control,
go to system -> appearance -> file list - turn off -> Show parent folder items .
Another question.
I have been trying to use Cinema Experience, I can play one movie, however if I stop that movie, then xbmc locks up and I have to restart the PC. Could this be connected with CE as otherwise movies play oK and there is no locking?
Wanilton I think you might have missed my question re CE
lja2014, I don´t have trouble with MQ5 and Cinema Experience, but I use XBMC helix, in this case better wait for other member use same XBMC..
iceman600, I don´t understand, if you refer image posted, when hidden, you have only items in collection, no more blank photo. Or post image again, my english is poor.
(2013-10-30, 15:45)MarcosQui Wrote: [ -> ]mikebzh44, look this:
How do I get that skin show me Media Cases ?
A: Aeon MQ use the 'tags' on the file name or folder to determine the type of case as follows:
bluray - blu-ray - bdrip (without .3d. or .3dbd. tag) = Bluray box
bluray - blu-ray - bdrip + .3d. or .3dbd. = 3D box
.3d. - .3dbd. = 3D box
web = Web box
hdtv = HDTV box
dvd - .iso (without bluray or any other tag) - .ifo = dvd box
All others contents = default box + codec
A example for the bluray case:
filename = moviename.bluray.mkv
So to see the case corresponding just rename the file with these tags above.
If no tag is used the skin show the video codec. Also you can customize the case as you wish, case color or flag.
Hi, i wonder if i can customize the tags making some changes in any xml file so i can follow my own renaming rules..
Would be great..if its possible..
thanks..
Is everything ok with MQ?,
Long time didnt see him here
Stupid question, I'm using logos in showart and I'm wondering if there is a way to increase the size of the logo's like the size they are in Aeon Nox?
(2014-08-05, 10:27)Megatron Wrote: [ -> ]Stupid question, I'm using logos in showart and I'm wondering if there is a way to increase the size of the logo's like the size they are in Aeon Nox?
You'll need to mod the code.
If you search this thread there was discussion on the same thing a few weeks/months back.
hi guys. live tv (IPTV addon) works on default skin confluence, but i get a blank black screen on MQ5. any way to fix this? thanks for any help in advance.
also, any news when the update to fix all the bugs gonna be?
Hi, i wonder if it is possible to edit the "smart shortcuts" to add some paths that i like enough..
does anybody know?
thanks.
Anyone an idea why this is happening? Already looked in ViewsShowArt.xml but don't really know what to look for.
Now I am here, how do i change the xml so the left top corner logo is bigger?
(2014-08-08, 19:26)hahaikke Wrote: [ -> ]
If you have questions relating to skinning (or modding) I would suggest putting them in the skin development forum where the experts hang out. Or check out the wiki. There's loads of helpful info their.
Thanks for the advise I fixed the messed up bottom part already.
