Hello,
I'm trying to install the skin in the new installation of XBMC (Windows 7 x64), I try throw the official repository, it downloaded correctly but doesn't install and doesn't show any error.
I try to doing the same with the .zip file but doesn't install.
what's the problem?
Which Kodi version is actually installed?
For Helix you should
CLICK ME
(2014-11-27, 17:06)lizard-king Wrote: [ -> ]Which Kodi version is actually installed?
For Helix you should CLICK ME
I've got the XBMC 13.2. Shoul I update a beta version?
Wrong bleeding MQ thread!!!
(2014-11-27, 18:41)VanZan Wrote: [ -> ]Has anyone had any trouble using this with the Slideshow screensaver? Not sure but I think there may be a incompatibility...I've changed to a different screensaver and it seems OK now.
Did you organize your artwork with artwork organizer? Slideshow works fine for me.
Can you guys use cinema experience with this addon? XBMC always crashes here if I try to start a movie with it.
Here's an excerpt from my log:
18:23:08 T:1000 NOTICE: -->Python Interpreter Initialized<--
18:23:08 T:1000 NOTICE: [Cinema Experience] - Script Name: Cinema Experience
18:23:08 T:1000 NOTICE: [Cinema Experience] - Script ID: script.cinema.experience
18:23:08 T:1000 NOTICE: [Cinema Experience] - Script Version: 4.0.10
18:23:08 T:1000 NOTICE: [Cinema Experience] - Starting Window ID: 10025
18:23:09 T:1000 NOTICE: [Cinema Experience] - Script Started With: movieid=5
18:23:09 T:1000 NOTICE: [Cinema Experience] - Video Playlist Cleared
18:23:09 T:1000 NOTICE: [Cinema Experience] - Music Playlist Cleared
18:23:09 T:1000 NOTICE: [Cinema Experience] - Movie ID Mode
18:23:09 T:1000 NOTICE: [Cinema Experience] - Movie ID: 5
18:23:09 T:1000 NOTICE: [Cinema Experience] - Library_view: oldway
18:23:09 T:1000 NOTICE: [Cinema Experience] - Storing Playlist in memory
18:23:09 T:1000 NOTICE: [Cinema Experience] - Retrieving Movie Details
18:23:09 T:1000 NOTICE: [Cinema Experience] - Rebuilding Movie Playlist
18:23:09 T:1000 NOTICE: [Cinema Experience] - Building Cinema Experience Playlist
18:23:09 T:1000 NOTICE: [Cinema Experience] - Adding Ratings Video
18:23:09 T:1000 NOTICE: [Cinema Experience] - Retriving Trailers: 3 Trailers
18:23:09 T:1000 NOTICE: [Cinema Experience] - Loading Saved List, Trailer Watched List
18:23:09 T:1000 NOTICE: [Cinema Experience] - Saving List, Watched Trailers
18:23:09 T:1000 NOTICE: Previous line repeats 1 times.
18:23:09 T:1000 NOTICE: [Cinema Experience] - Adding Trailers: 0 Trailers
18:23:09 T:1000 NOTICE: [Cinema Experience] - Playlist Size: 1
18:23:09 T:1000 NOTICE: [Cinema Experience] - Trigger List Size: 1
18:23:09 T:1000 NOTICE: [Cinema Experience] - Saving List, Trigger List
18:23:09 T:656 ERROR: m_pD3DDevice->BeginScene() failed. 8876086C - D3DERR_INVALIDCALL (Invalid call)
18:23:27 T:656 ERROR: Previous line repeats 133 times.
18:23:27 T:656 NOTICE: Storing total System Uptime
18:23:27 T:656 NOTICE: Saving settings
18:23:27 T:656 NOTICE: stop all
18:23:27 T:656 NOTICE: stop player
On the skin Neon it works fine.
Any ideas?
Just made a fresh installation of XBMC and MQ5, same sh**...
19:13:10 T:356 ERROR: m_pD3DDevice->BeginScene() failed. 8876086C - D3DERR_INVALIDCALL (Invalid call)
19:13:50 T:356 ERROR: Previous line repeats 286 times.
Always the same: First time it works. After restart of XBMC it doesn't work anymore. When I change the skin to Neon and back to MQ5 it works again once... very strange
I love this skin! I am using openelec on a custom built mini atx system. It is running great but the one problem that I am having with the skin is that when my system comes out of sleep mode there are no backgrounds displaying. I have fanart set as the backgrounds. Can anyone help with this?
I've just installed MQ5, excellent, congrats'
A question, how do i change the view in movies, TV shows ... N
Press arrow left and up twice.
Using gotham 13.2, All of my movies are SBS
Im trying to figure out how to name my 3D movies. I had it working once but I lost my 3D collection and can't remember what the tags were.
I have tried naming quite a few times and can't get it right. It's just a pain having to rename, wait a few min for it to scan, then try again, then rename, wait for it to scan...
I want it to show the 3D cover and I want xbmc to recognize that its a 3d movie and either automatically switch to SBS (preferred), or prompt me to pick which 3d mode I would like.
So far the closest Ive got it to work:
Sin City - A Dame to Kill For (2014) 3D.SBS.mkv
- Aeon MQ 5 doesnt change it to a 3D cover, must be the wrong tag.
(I tried searching "3D tag" in this thread, but its too short)
- XBMC detects that its a sbs movie and changes the screen to sbs (doesnt change my LG TV mode to 3D tho) BUT
when I stop the movie it doesnt change back to a normal screen. The only way I could figure out how to change it back was to exit xbmc and re-open it.
Can anyone help me fix this please
For me, what works is Movie (year).3d.hsbs.mkv (or whatever format).
(2014-12-01, 00:13)Samu-rai Wrote: [ -> ].3DBD
This changed the movie case to 3D, but xbmc did not recognize it as a 3D movie.
(2014-12-01, 00:49)patseguin Wrote: [ -> ]For me, what works is Movie (year).3d.hsbs.mkv (or whatever format).
This worked for both!
Now all I just have to figure out how to get my TV to automatically change and it'd be perfect, but this is great for now.
Thanks alot!
If you want to tell kodi what kind of 3d it is do the following:
Sin City 3D.3DBD.SBS.mkv (for sbs)
For HOU 3D use .TAB. instead.
Go to options and use the option to let kodi choose what kind of 3d it is by itself. Using the above additions works like a charm for sbs and hou.
What he wants is his TV t change automatically to 3D mode, but I think that is impossible because xbmc doesn't send any 3D signal to the TV.
