2013-10-31, 23:59
(2013-10-28, 14:38)sfnetwork Wrote: [ -> ](2013-10-27, 05:49)sfnetwork Wrote: [ -> ](2013-10-27, 00:00)sfnetwork Wrote: [ -> ]I know, this is why I did ALL those tests to isolate the source of the issue before mentioning it here, I presumed already that the command was the same as Ace...
I'll try again (delete EVERYTHING related the MQ5) and redownload a new copy in case...
***BTW, I don't think the command is the issue, it's more how the skin generates the screen IMO...
Anyway, I'll let you know... I just don't want to use ACE now that I tasted to MQ5, lol...
OK, on one of my HTPC, I did a complete rebuild (this one is Openelec) and it still did it (again, Ace; no issue). So there is really "something" different in MQ5 that may need a fix (and two of my 5 HTPCs are fine so I know some users have no issue; doesn't mean there is no problem).
I started isolating features that would be involved that doesn't exist in Ace. I may have found one; custom watched indicators...
I may be wrong but I ALWAYS use the eye one with black background... I tried disabling the watched indicators from the views...
Since then, so far, never crashed on black screen...
I will have to test more to confirm but so far, it may be related...
I have some test result (positive).
I can't be 100% of which of those two test corrected it (yet) but additionally to stop using custom watched flags I decided to redo the SQL databases from scratch.
I was using centralized MySQL configuration.
To make this really clean, I uninstalled MySQL and deleted everything (database, etc...) from server.
I installed the latest MySQL and recreated the XBMC SQL user, etc...
I rescanned my entire library to it.
And, I used Trakt to resync my watched states.
(only thing I lost was the "resume" points; not really important)
From this moment, I haven't had the black screen issue yet at all when going to "recently added" from sub menu.
I'll test reactivating my favorite watched indicator in MQ5 (the eye on black background one) and see if I'm still stable.
So, so far. I isolated the issue source to be the SQL database or the watched indicators...
Sorry to bring this back in your face again but after sooo much time on this issue (and money since I tried changing a ssd drive), I can't confirm that ONLY MQ5 has this issue.
ACE which is the closest in terms of design/screens never has this issue in my tests...
So far, here are what I tried:
-Different GPU card (also AMD and nVidia)
-Different TV/monitor
-Different ssd drive (including complete rebuild , Openelec)
-Redownload skin (and deleted all references in addons and packages (not relevant with previous test)
-Different cable (HDMI/DVI)
-Different resolution
-enable/disable watched indicator
-Complete SQL rebuild with new databases with new scanned library (centralized SQL using mySQL)
-Many different options in skin (all of them I think, lol)
This only happenning on specific PCs and I can't isolate why (one is Intel based and the other is AMD...)
Nothing in the logs about it...
To reproduce this (as a reminder), from home screen, I go in "Movies" submenu in "recently added" then from time to time, it goes to a black screen and stays like this until I reboot...
There MUST be something different when the screen is generated when going in "recently added" from sub menu between MQ5 and ACE, it wouldn't make sense that it's EXACTLY the same...
And since others (not alot) also reported this... I think it must be specific to a hardware but I just can't target it... And Since ACE is perfect in this area...
I just LOVE MQ5 so this is why I worked that hard to try to fix it but unfortunately for me, I will have to stick with ACE...
Really hope this can be fixed... (If we could ever find the issue...)
