2013-11-06, 00:10
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208
2013-11-06, 00:14
(2013-11-06, 00:10)Shftup Wrote: [ -> ]Thanks MQ.
Silly question, but how can I get your latest skin - MQ5? (using MQ4 now)
thanks
S
It's in the official repo, under skins.
2013-11-06, 01:57
Is there anything I can modify in the options or in the skin itself to make the selected item in wall view for file mode to more obvious?
2013-11-06, 05:31
Great skin!
One issue. I'm using some smart playlists and every time I go to the main menu I get:
Script Failed! randomandlastitems.py
I can see the following in the log:
22:07:52 T:3916 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: (22, "invalid mode ('rb') or filename", 'smb://192.1.1.100/storage/3/xbmc/userdata/playlists/video/MOVIES SP.xsp')
File "C:\Users\bob\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 723, in <module>
_parse_argv()
File "C:\Users\bob\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 644, in _parse_argv
_getPlaylistType ();
File "C:\Users\bob\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 46, in _doc = parse(xbmc.translatePath(PLAYLIST))
File "C:\Program Files (x86)\XBMC\system\python\Lib\xml\dom\minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "C:\Program Files (x86)\XBMC\system\python\Lib\xml\dom\expatbuilder.py", line 922, in parse
fp = open(file, 'rb')
IOError: (22, "invalid mode ('rb') or filename", 'smb://192.143.74.210/storage/3/xbmc/userdata/playlists/video/MOVIES SP.xsp')
Any ideas?
_parse_argv()
Any ideas?
2013-11-06, 08:04
2013-11-06, 08:59
Request help on:
1. The 12 widgets of main menu item Music are no longer there and I cannot get them back even though 12 Widgets for Music are enabled in MQ5 skin settings
2. On playing a music file, the screen which showed a CD rotating and lyrics, also displayed background images of the artist being played which were being obtained from the internet. TThese background images are no longer being displayed though theCd and lyrics still are. This happened after I switched to MQ5 5.1 for Frodo. Possible some addons settings got changed and I cannot figure out which ones.
Appreciate any help Thanks.
2013-11-06, 09:32
(2013-11-06, 05:31)theredguy Wrote: [ -> ]Great skin!
_parse_argv()
Any ideas?
I don't think that storing smart playlist on a NAS or another computer is a good think.
Can you try with smart playlists stored locally ?
2013-11-06, 09:35
After wiping my entire XBMC install, including my profile, then reinstalling both XBMC gotham and MQ5 the Artist Slideshow now works, but I still receive an error when trying to install / update the extrapack... I know there's a manual download, but was this issue not resolved?
This is the error:
This is the error:
21:41:02 T:4972 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: function takes exactly 1 argument (0 given)
File "C:\Users\media\AppData\Roaming\XBMC\addons\script.aeonmq5.extrapack\default.py", line 13, in <module>
updater = Updater()
TypeError: function takes exactly 1 argument (0 given)
21:41:06 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_modern\
21:41:06 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_modern/
21:41:10 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_future\
21:41:10 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_future/
21:41:11 T:4188 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_cold\
21:41:11 T:4188 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_cold/
21:41:11 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_warm\
21:41:11 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_warm/
21:41:11 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_darkness\
21:41:11 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_darkness/
21:41:12 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\media\AppData\Roaming\XBMC\userdata\addon_data\skin.aeonmq5.extrapack\backgrounds_digitalart\
21:41:12 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://userdata/addon_data/skin.aeonmq5.extrapack/backgrounds_digitalart/
21:41:12 T:3896 ERROR: XFILE::CDirectory::GetDirectory - Error getting /
21:41:15 T:4528 NOTICE: Thread LanguageInvoker start, auto delete: false
21:41:15 T:4528 NOTICE: -->Python Interpreter Initialized<--
21:41:15 T:4528 NOTICE: start aeonmq5 updater
21:41:15 T:4528 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
updater = Updater()
2013-11-06, 12:41
(2013-11-05, 22:07)sfnetwork Wrote: [ -> ]It's a little weird how it closes the submenu first then switch to the screen BUT it works.
1 new file in folder, test again please.
2013-11-06, 14:20
(2013-11-06, 09:32)mikebzh44 Wrote: [ -> ](2013-11-06, 05:31)theredguy Wrote: [ -> ]Great skin!
_parse_argv()
Any ideas?
I get this error on windows test machine, but not on my main OPENELEC. Both using NAS as storage device.
2013-11-06, 16:06
(2013-11-04, 18:55)wouterdt Wrote: [ -> ](2013-11-04, 18:00)Manos Wrote: [ -> ]Nice skin!
Is it possible to hide watched items from widgets?
I have the same question, in the widget settings I enabled "only unplayed and unfinnished" but it keeps showing me movies that have the watched status. My movies is a playlist so that might be the issue?
I have the same issue. Any solution?
2013-11-06, 16:29
2013-11-06, 19:36
2 new files in folder, test again please.
2013-11-06, 20:10
(2013-11-06, 19:36)MarcosQui Wrote: [ -> ]2 new files in folder, test again please.
Sorry, no. (I had to try more to reproduce it this time but it might just be a coincidence.. )
2013-11-06, 20:25
To avoid a lot of message here, we will resolve it in offline please. By PM is better.
