(2013-11-24, 11:27)Morbeas Wrote: [ -> ]I tried adding 3DBD but that didn't work for me.
Think if you go to where you can modify the cover colours there are some more switch in the explanation , like I said I did have issues with MQ5 but all worked perfect in MQ4
It is possible to have the start up screen on a custom widget. Let's say I have a Home widget, can I define it as a preset one, then it should appear on the options of the start up window? Do I have to define it as a home window? I've tried various methods, any suggestions or answers?
(2013-11-23, 11:31)SALAMINOMACHOS Wrote: [ -> ] (2013-11-22, 22:03)iblong Wrote: [ -> ] (2013-11-22, 21:59)Wanilton Wrote: [ -> ]Available in official frodo repository. in XBMC, go to settings-> addons -> get addons-> skin -> Skin Aeon MQ 5.
I did that but the version wasn't 5-1.7.4............it was 5-1.6........I do not understand?
Even though it shows the Cinema Experience , the Version still remains 1.6.3
Marcos thanks for the Cinema Experience ...........
GREAT.
Now it shows the updated version 1.7.4
Thanks a lot
About 3D cases, it´s simple to fix, need only have tag 3DBD in filaneme, but have one detail, need dot (.) before tag like this .3DBD, no space blank. example:
its ok Transformers Dark Of The Moon.3DBD
no more Transformers Dark Of The Moon 3DBD
then rescan that movie from within the movies info section will work
How do I go about donating to this skin? I would really like to update from MQ4 but don't have the option from the repo. Your hard work deserves a contribuation
Liam
craney, about donation, look in MarcosQui signature, have instruction about.
Thanks for fixing MQ5 in Gotham nightly! I've noticed that with MQ5 over confluence or other skins supported in Gotham that MQ5 uses WAY more CPU than expected. I was able to decrease idle cpu usage by using the fade effect even though I don't have a weaker gpu. Is there anything else I can configure to tune down the idle CPU usage since I leave my HTPCs on 24/7 but idling at low wattage.
Hi Guys,
I'm using Live TV with WMC PVR + Aeon MQ5.
My upcoming recordings don't seem to have artwork. How do I fix this?
(2013-11-23, 17:43)starkos Wrote: [ -> ] (2013-11-10, 15:32)starkos Wrote: [ -> ] (2013-11-07, 01:18)starkos Wrote: [ -> ]Hi, when the home screen widget for TV Shows is set to display 'In Progress' items, it doesn't appear to show the season and/or episode number for any of the items? Can anyone else confirm this please? Thanks
(Gotham Alpha 9 & MQ5 1.5.1)
Thought I would give this a quick bump as it's still present in 1.6.3. Anyone else have this problem? Thanks
Hi, the problem is still there in 1.7.4. I'll try attaching 2 screenshots to show what I mean. Can anyone else can confirm this?
Will be fixed in version 1.8.x
(2013-11-24, 00:25)francovilar Wrote: [ -> ] (2013-11-23, 19:52)starkos Wrote: [ -> ] (2013-11-23, 19:22)francovilar Wrote: [ -> ]I can't believe that I'm the only one having this problem.. third system I try and same thing in all 3... time to change skin.
Never used fixed list before so no idea how it previously behaved, but I can confirm that when returning to the home menu it always jumps to Movies.
(Gotham, MQ5 1.7.4)
Thank you. MQ, can you please fix main menu with fixed list?
Thank you for the fix.
feature request: a Kiosk mode to home menu widgets.
Good evening MarcosQui,
1) The availability of the new scraper LIO (Local Information Only) from XBMC team embedded in XBMC Gotham is very welcome, however in the tests I am conducting (latest Gotham nightly for OS X 10.9), it doesn't seem to work well yet with MQ5. I am getting no local posters for instance:
LIO 1.0.0 Scraper:
No Poster scraped from local files (format: poster.jpg or <movie>-poster.jpg):
2) It would be great if you could have an option in MQ5 for displaying both movie titles: The <title> and the <originaltitle> at least from the NFO file, if read locally (or from online database if pulled in via online scraper TMDB or UMS, for instance). This is so great and most skins do not contemplate how useful to users this info is! Specially when movies from so many different countries and languages are present in the movie library.
(2013-11-23, 23:18)Wanilton Wrote: [ -> ]T800, look in the first post in this thread, have all addon necessary for skin run ok, install addon by addon, and after install skin, this solve I think.
I've tried adding all the addons still nothing. Quite a lot of them are incompatible. Even Aeon MQ5 says it's incompatible in the addons section.
I've tried removing all addons.
I cannot get it to work at all.
(2013-11-24, 19:24)francovilar Wrote: [ -> ]Thank you for the fix.
So the widgets can't be adjusted when you press down after highlighting? I like that idea!
(2013-11-24, 22:04)T800 Wrote: [ -> ] (2013-11-23, 23:18)Wanilton Wrote: [ -> ]T800, look in the first post in this thread, have all addon necessary for skin run ok, install addon by addon, and after install skin, this solve I think.
Still having issues as well, tried installing all the addons but still no joy
