Full Version: How to edit movie genre
Some movies have a wrong genre. How can I edit this info?
- Frodo 12.2 + AEON NOX
If the genre is blatantly and obviously wrong, you can register on the movie info site (themoviedb.org) and correct this information for the benefit of everybody. However, if it's more of a matter of your wanting to add another genre or you feel another genre better describes the movie, you can create an nfo file for it and specify your additional or replacement genre. See here: http://wiki.xbmc.org/index.php?title=NFO_files/Movies
Pulp fiction was saved as "1984" genre! However the scraper is using an italian site mymovies.it.... may be wrong?
Not familiar with that site, so I don't know if it's community-based and whether you can edit the content there. If not, then use the nfo file approach.
BTW is there a way to instructMC to use one particular scraper among many?
You can specify using one scraper for some movies and a different scraper for others. Just open the context menu, select "Change content" and then the desired scraper.
(2013-09-30, 07:50)artrafael Wrote: [ -> ]You can specify using one scraper for some movies and a different scraper for others. Just open the context menu, select "Change content" and then the desired scraper.
You mean while in the movie list?
While displaying your video folders/files: VIDEOS > Files > navigate to the desired folder/file
