Full Version: adding an EXE to the homescreen
first off, fantastic skin, clean and simple!
If I could get help with one thing though. Is there a way i can attach an exe to the home screen? (example have an option on the horizontal home bar named "Games" that when clicked opens an external exe)
thanks.
(2013-10-02, 04:52)asskickulater Wrote: [ -> ]first off, fantastic skin, clean and simple!
thanks.
hi,
take a look here
i never used with bello, but i think it doesn't need particular integration in the skin.
you can select an exe file through "advanced launcher" and then set it as favoutire on the media bar.
i suppose it should work......
Peppe
ohhh I never thought of that, I'll give it a try and report back, thanks!
Edit:
Thank you very much! That did it. this was the deal breaker for me if I couldn't add that to the main menu
thank you to both you and Nessus!
