Is there any plans for this scraper to be like tv shows and movies? would be great if it works the same be a section in kodi that says sports and has all the games of nba and ufc available
(2015-04-18, 12:46)freddy12 Wrote: [ -> ]Is there any plans for this scraper to be like tv shows and movies? would be great if it works the same be a section in kodi that says sports and has all the games of nba and ufc available
This is currently being discussed here
http://forum.kodi.tv/showthread.php?tid=216044... The addon kind of works like that. Sports isn't currently a media type that Kodi uses like Movies or TV Shows... So when it's ready I'm planning on making a custom Main Menu Item that starts the addon form the main menu. Enen92 has made great strides with the addon I suggest checking it out
http://forum.kodi.tv/showthread.php?tid=216044 .
zag, sorry to bother you.
I am trying to get events on "my database" to list. Can you explain what the difference is between event thumb and event fanart? I understand that poster is like movie posters but I can't see fit for an event thumb, specially with that huge resolution (720p).
Can you provide some examples of events with this type of art defined on thesportsdb?
As already mentioned some posts ago, I would prefer the thumb in the standard size of 500x281 pixels as it usually used for TV shows
Yes, that's what I think as well. For lower dimension images priority is given to event fanart, then if fanart is not available -> thumb, then probably user defined priority fanart (stadium, hometeam fanarts, league fanart...). I will ignore thumbs as fanart in my addon. Will use it (if available) only for smaller images.
Well, now only at night. Big game coming
I'm almost finishing the event listing stuff. Those events will certainly help
Is this working yet? Is there an add-on that needs to be downloaded?
(2015-04-29, 15:48)zag Wrote: [ -> ] (2015-04-29, 15:43)ShepsCrook Wrote: [ -> ]Is this working yet? Is there an add-on that needs to be downloaded?
Yep, it has not been released yet, but you can check progress here
Darn, was hoping to get some of these rugby games scraped.
(2015-04-29, 16:54)ShepsCrook Wrote: [ -> ] (2015-04-29, 15:48)zag Wrote: [ -> ] (2015-04-29, 15:43)ShepsCrook Wrote: [ -> ]Is this working yet? Is there an add-on that needs to be downloaded?
You will. Addons like these are huge. People usually forget the work and time that one needs to put into get stuff like this to work. Just for you to have an idea, the addon above is probably 60% finished for 1 skin and has already 82596 lines of code (of course counting with the lines for skin windows xml files).
(2015-04-29, 16:57)enen92 Wrote: [ -> ] (2015-04-29, 16:54)ShepsCrook Wrote: [ -> ] (2015-04-29, 15:48)zag Wrote: [ -> ]Yep, it has not been released yet, but you can check progress here
Oh I know it's not easy. If it was easy, I would have done it myself.
Just a small improvement for soccer but I have written a quick lookup for Football Manager ID's
http://www.thesportsdb.com/pmsearch.php
Unfortunately the only database that I could find was from 2009. Let me know if anyone has an updated one.
This allows you to search for a player and find a transparent "cutout" of the players face from various places around the internet.
In order to have more people adding info to the DB, Zag, what do you think about activating the 'Charts' page displayed on the bottom of the page? Something similar to fanart.tv will be great
PS: BTW, please have a look @ thesportsdb.com forum as there are some issues which need your attention
