2013-10-02, 20:34
Hey guys,
Been searching around and cant find the answer so I thought I'd ask!
I know I can remove movies from the library, but can I actually delete them directly from my hard disk? I don't have much space and when I try and delete over the network, often it says file in user
DK
EDIT: I continued searching and found the answer! Under settings -> video -> library, enable edit and delete. Then when you remove from the library it asks you if you also want to delete.
DK
