I'm wondering if we can submit skin to the Gotham repo? As far as I know, I've done what was listed in the thread listing the changes to the skin engine.
you could however some key essential things are missing atm so not easy to distribute it. handling inside xbmc for example as we want a combined frodo/gotham repo.
dev skin repo should be a bit easier to add.
will keep you guys posted.
ok, will wait then.
