2013-10-03, 00:33
Hi there;
I have a 10Moons D6 (aka, Bluetimes MX5) which is said to be very similar to Geniatech ATV1200.
I am using the latest Pivos nightly build supplied in the Pivos forums, and all seemed to work fine including hardware acceleration for HD video.
In order to fix some issues (namely network disconnections) and to get advantage of new features announced by the manufacturer (ie; CEC) I installed the most recent firmware version. Unfortunately I have found the same problem that later on I have discovered some others have found too; *any* video (not only HD) fails to reproduce the video part. Audio starts playing with a black screen, returning back to the menus. You can return to main screen and switch to "Full Screen" with a black screen, and even if you enable subtitles you can see them against a black background.
I have rolled back firmwares and found this happens from the firmware versions available from mid-august, and strange enough I observed some of the related files have changed sizes on the firmwares that do not work (ie; libamplayer.so) indicating a change in the affected area.
Enabling debug in XBMC, I got an error that means nothing to me being a newbie, but can explain something to experienced eyes:
00:02:54 T:1692774520 DEBUG: CAMLCodec::OpenDecoder
00:02:54 T:1692774520 DEBUG: codecid_to_vformat, id(28) -> vformat(2)
00:02:54 T:1692774520 DEBUG: codec_tag_to_vdec_type, codec_tag(28) -> vdec_type(4)
00:02:54 T:1692774520 DEBUG: CAMLCodec::OpenDecoder hints.fpsrate(1767011598), hints.fpsscale(73699223), hints.rfpsrate(24000), hints.rfpsscale(1001), video_rate(4004)
00:02:54 T:1692774520 DEBUG: CAMLCodec::OpenDecoder hints.aspect(1.846154), video_ratio.num(1), video_ratio.den(1)
00:02:54 T:1692774520 DEBUG: CAMLCodec::OpenDecoder hints.orientation(0), hints.forced_aspect(1), hints.extrasize(35)
00:02:54 T:1692774520 DEBUG: CAMLCodec::OpenDecoder codec init failed, ret=0x100000a
00:02:54 T:1692774520 ERROR: DVDVideoCodecAmlogic: Failed to open Amlogic Codec
Any hint?
Thanks in advance.
Any hint?
Thanks in advance.
