(2014-02-02, 09:28)fritsch Wrote: [ -> ]@Jarlakxen: You did at least not follow the howto concerning your username. Did you set all permissions correctly?
I see lots of unplayable items in your home directory. Even the mp4 file that gets "half" opened, does not want to open vdpau at all.
Yes, i have another user but i executed the command "sudo usermod -a -G cdrom,audio,video,plugdev,users,dialout,dip mcenter". I saw the messages of the unplayable items in the logs but the videos are fine, i can play it with VLC. Is there any way to know of why XBMC tells that the videos are unplayable?
fritsch "Pssst, don't tell anyone:
http://sprunge.us/geNf"
Is that why my a4 3400 plays h.264 29.97i (59.94) much better on 10.02? Or can just expect even better performance soon?
Edit: Never mind looks too new...
Patch applied, A8-6500 (Radeon HD 8570D IGP):
First column-before, second-after:
MPEG DECODING (1920x1080) 83 frames/s 136 frames/s
MPEG DECODING (1280x720) 126 frames/s 297 frames/s
H264 DECODING (1920x1080) 54 frames/s 73 frames/s
H264 DECODING (1280x720) 96 frames/s 172 frames/s
Profile unsupported.
MPEG4 DECODING (1920x1080) 78 frames/s 122 frames/s
MIXER WEAVE (1920x1080) 1161 frames/s 1167 frames/s
MIXER BOB (1920x1080) 1623 fields/s 1653 fields/s
MIXER TEMPORAL (1920x1080) 1764 fields/s 1768 fields/s
MIXER TEMPORAL + IVTC (1920x1080) 1757 fields/s 1765 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080) 1756 fields/s 1767 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080) 1748 fields/s 1784 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080) 1759 fields/s 1732 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080) 1748 fields/s 1788 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display) 2134 fields/s 2140 fields/s
MULTITHREADED MPEG DECODING (1920x1080) 34 frames/s 35 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080) 1908 fields/s 1925 fields/s
After reading about these promissing results I decided to wipe my old installation and follow the howto.
I came across the issue that xbcm does not get started automatically. Starting it manually gives;
Error: unable to open display
XBMC needs hardware accelerated OpenGL rendering.
Install an appropriate graphics driver
When I try the command startx, Xorg does not start with the MESA drivers but is crashed (photo:
http://i.stack.imgur.com/xIG9s.jpg). Anyone a clue where it goes wrong?
dmesg:
http://paste.ubuntu.com/6872453/
Xorg.log:
http://paste.ubuntu.com/6872454/
Mesa:
http://paste.ubuntu.com/6872546/
xbmc: log not present.
Thanks in advance!
did you delete your old installation? in my case I had to format the drive completely otherwise residual files interefered...
(2014-02-03, 21:49)fritsch Wrote: [ -> ]Pssst, don't tell anyone: http://sprunge.us/geNf
Before:
Quote:VDPAU implementation : G3DVL VDPAU Driver Shared Library version 1.0
FATAL: get_bits failed : No backend implementation could be loaded.!!
MPEG DECODING (1920x1080): 60 frames/s
MPEG DECODING (1280x720): 85 frames/s
H264 DECODING (1920x1080): 33 frames/s
H264 DECODING (1280x720): 61 frames/s
MPEG4 DECODING (1920x1080): 45 frames/s
MIXER WEAVE (1920x1080): 301 frames/s
MIXER BOB (1920x1080): 511 fields/s
MIXER TEMPORAL (1920x1080): 144 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 139 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 153 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 147 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 140 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 155 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display): 252 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 20 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 138 fields/s
After:
Quote:AMD A4-5000 APU with Radeon HD Graphics
Unknown GPU
VDPAU API version : 1
MPEG DECODING (1920x1080): 110 frames/s
MPEG DECODING (1280x720): 244 frames/s
H264 DECODING (1920x1080): 44 frames/s
H264 DECODING (1280x720): 115 frames/s
MPEG4 DECODING (1920x1080): 69 frames/s
MIXER BOB (1920x1080): 509 fields/s
MIXER TEMPORAL (1920x1080): 142 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 142 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 155 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 141 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 138 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 158 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 24 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 137 fields/s
1080p60 works now!!!
1080p50 also
That's brilliant - I tested on my Kabini.
Samples:
https://dl.dropboxusercontent.com/u/5572...f-HDTV.mkv
https://dl.dropboxusercontent.com/u/5572...recode.mkv
mesa upgraded to 10.0.3 + this patch in the test PPA. Feedback welcome
thanks wsnipex!
i was about to really mess up and try to apply this patch to the kernel.
lol :-)
Edit: @locomot1f: Does it work? If yes, the packages can be copied over. What's your speed improvement?
it does work... no flickering. videos play smoothly.
i don't have qvdpautest installed, so I can't give you any real numbers -- sorry :/
Hmmm I'd give it a test but I'm not sure if it will break my 'kinda working' MPEG-2 ;D
(2014-02-04, 15:43)schnappi Wrote: [ -> ]did you delete your old installation? in my case I had to format the drive completely otherwise residual files interefered...
Yes, I did format the partition .... It is a clean saucy-mini installation as the tutorial tells to do.
installed the test ppa
EDIT: so far no playback problems.
previous
lee@Fusion:~$ cat qvdpautest.txt
qvdpautest 0.5.2
AMD E-350 Processor
Unknown GPU
MPEG DECODING (1920x1080): 58 frames/s
MPEG DECODING (1280x720): 90 frames/s
H264 DECODING (1920x1080): 36 frames/s
H264 DECODING (1280x720): 68 frames/s
VC1 DECODING (1440x1080): 83 frames/s
MPEG4 DECODING (1920x1080): 50 frames/s
MIXER WEAVE (1920x1080): 274 frames/s
MIXER BOB (1920x1080): 370 fields/s
MIXER TEMPORAL (1920x1080): 454 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 452 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 456 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 452 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 455 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 452 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display): 566 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 54 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 466 fields/s
now
lee@Fusion:~/qvdpautest$ ./qvdpautest
qvdpautest 0.5.2
AMD E-350 Processor
Unknown GPU
MPEG DECODING (1920x1080): 91 frames/s
MPEG DECODING (1280x720): 203 frames/s
H264 DECODING (1920x1080): 48 frames/s
H264 DECODING (1280x720): 119 frames/s
MPEG4 DECODING (1920x1080): 74 frames/s
MIXER WEAVE (1920x1080): 275 frames/s
MIXER BOB (1920x1080): 385 fields/s
MIXER TEMPORAL (1920x1080): 135 fields/s
MIXER TEMPORAL + IVTC (1920x1080): 120 fields/s
MIXER TEMPORAL + SKIP_CHROMA (1920x1080): 128 fields/s
MIXER TEMPORAL_SPATIAL (1920x1080): 123 fields/s
MIXER TEMPORAL_SPATIAL + IVTC (1920x1080): 120 fields/s
MIXER TEMPORAL_SPATIAL + SKIP_CHROMA (1920x1080): 128 fields/s
MIXER TEMPORAL_SPATIAL (720x576 video to 1920x1080 display): 210 fields/s
MULTITHREADED MPEG DECODING (1920x1080): 91 frames/s
MULTITHREADED MIXER TEMPORAL (1920x1080): 147 fields/s
