(2015-03-09, 15:31)fritsch Wrote: [ -> ]dvix/xvid accel is working by luck ;-) as during the xvid/dvix period there were a lot of different coders, formats differences and so on - I would just disable acceleration for those.
What exactly I should disable in Kodi settings?
Sorry for noob question.
Mpeg-4 and depending on your gpu (if it's a hd5000) also Mpeg-2
Nothing for pastebin, so i do it like this:
Somewhere found to post also ls -l /dev/snd/, so here it is...
pana@knedlik:~$ aplay -l | pastebinit
aplay: device_list:268: no soundcards found...
You are trying to send an empty document, exiting.
pana@knedlik:~$ ls -l /dev/snd/
total 0
drwxr-xr-x 2 root root 80 Apr 11 12:28 by-path
crw-rw---- 1 root audio 116, 4 Apr 11 12:28 controlC0
crw-rw---- 1 root audio 116, 10 Apr 11 12:28 controlC1
crw-rw---- 1 root audio 116, 3 Apr 11 12:28 hwC0D0
crw-rw---- 1 root audio 116, 9 Apr 11 12:28 hwC1D0
crw-rw---- 1 root audio 116, 2 Apr 11 19:50 pcmC0D3p
crw-rw---- 1 root audio 116, 8 Apr 11 12:28 pcmC1D0c
crw-rw---- 1 root audio 116, 7 Apr 11 19:50 pcmC1D0p
crw-rw---- 1 root audio 116, 6 Apr 11 19:50 pcmC1D1p
crw-rw---- 1 root audio 116, 5 Apr 11 12:28 pcmC1D2c
crw-rw---- 1 root audio 116, 1 Apr 11 12:28 seq
crw-rw---- 1 root audio 116, 33 Apr 11 12:28 timer
Jo - no soundcards found ... or most likely you are not in the audio group.
From what I see you don't run the user I have told to use in that howto. So fix your permission issue:
sudo adduser pana audio
sudo adduser pana video
sudo reboot
(2015-04-11, 20:07)Pana_Ruplahlava Wrote: [ -> ]Did not know that it is for certain user, now for xbmc user:
http://paste.ubuntu.com/10802353/
card 1: SB [HDA ATI SB], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
Can't you just provide all the logs the howto on page 1 wants to have? At least there _is_ your output device. That you need to set as your PCM device.
Quote:12:28:17 T:140256810764224 NOTICE: Device 2
12:28:17 T:140256810764224 NOTICE: m_deviceName : @:CARD=SB,DEV=0
12:28:17 T:140256810764224 NOTICE: m_displayName : HDA ATI SB
12:28:17 T:140256810764224 NOTICE: m_displayNameExtra: ALC887-VD Analog
12:28:17 T:140256810764224 NOTICE: m_deviceType : AE_DEVTYPE_PCM
12:28:17 T:140256810764224 NOTICE: m_channels : FL,FR
12:28:17 T:140256810764224 NOTICE: m_sampleRates : 48000
12:28:17 T:140256810764224 NOTICE: m_dataFormats : AE_FMT_S32NE
System -> Settings -> Systems -> Audio Output:
Audio Output Device: HDA ATI SB (ALC887-VD Analog) or how it's called
Enabe Passthrough: disabled.
Im confused too, because ive been trying this setting before and it is not working. Re-tested now...
No idea what you mean with "not working" make a screenshot when you set that device. If "non working" means muted, then just unmute the device.
Edit: And post a
Debug Log (e.g. turn debugging on, change device), post logfile in that order
use alsamixer -c1 to unmute it
The crashlog was 13.2 :-) hahahaha
Did not read the log, just copypaste...
BUT! It was muted! Working like a charm now! Thank you a lot!
