?uestion -- should we be using oibaf, or wsnipex ppa?
personally i'd use wsnipex repo, i'm assuming wsnipex are known working snapshots of oibafs ppa.
On the PVR, my HD channels work great, but when I switch to an SD channel, XBMC crashes. Has anyone else had this issue?
Hello,
I'm running xbmc xvba for a long time, but some limitations (especially sound over hdmi) force me to move on the radeon uvd.
Thank for your how to, but I can't enjoy it today because I'm running under 32bits.
So I have 2 questions : where can I find the source of linux image 3.12RC7 32bits ?
And what is the proper way to patch source ?
(2013-10-31, 21:10)dan_jericho Wrote: [ -> ]On the PVR, my HD channels work great, but when I switch to an SD channel, XBMC crashes. Has anyone else had this issue?
Pastebin your crash, before do: sudo apt-get install gdb
just for clarification if you are using this method with the newer kernel 3.12 and have an external usb ir receiver then you need to change
/etc/udev/rules.d/85-xbmc.rules
first line "usb" to "usbmisc", per FernetMenta the newer kernels require usbmisc instead of usb.
probably should include that in the post
all is working well now, thanks for putting this together, this is way better than catalyst!!!
Hello all,
how can I force the screen size for a size that is not listed by xrandr?
I would like to have a size like 1366x768, because XBMC screen, currently is bigger than the screen.
Screen 0: minimum 320 x 200, current 1280 x 720, maximum 8192 x 8192
HDMI-0 connected 1280x720+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1280x720 60.0*+ 50.0 59.9
1920x1080i 30.0 25.0 30.0
1440x576 50.0
1440x480 60.0 59.9
720x576 50.0
720x480 60.0 59.9
640x480 60.0 59.9
DVI-0 disconnected (normal left inverted right x axis y axis)
VGA-0 disconnected (normal left inverted right x axis y axis)
xxx@yyy:~$ DISPLAY=:0 vdpauinfo
display: :0 screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name width height types
420 16384 16384 NV12 YV12
422 16384 16384 UYVY YUYV
444 16384 16384 Y8U8V8A8 V8U8Y8A8
Decoder capabilities:
name level macbs width height
MPEG1 0 9216 2048 1152
MPEG2_SIMPLE 3 9216 2048 1152
MPEG2_MAIN 3 9216 2048 1152
H264_BASELINE 41 9216 2048 1152
H264_MAIN 41 9216 2048 1152
H264_HIGH 41 9216 2048 1152
VC1_ADVANCED 4 9216 2048 1152
MPEG4_PART2_SP 3 9216 2048 1152
MPEG4_PART2_ASP 5 9216 2048 1152
Output surface:
name width height nat types
B8G8R8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8
R8G8B8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8
R10G10B10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8
B10G10R10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8
Bitmap surface:
name width height
A8 16384 16384
Video mixer:
feature name sup
DEINTERLACE_TEMPORAL -
DEINTERLACE_TEMPORAL_SPATIAL -
INVERSE_TELECINE -
NOISE_REDUCTION y
SHARPNESS y
LUMA_KEY -
HIGH QUALITY SCALING - L1 -
HIGH QUALITY SCALING - L2 -
HIGH QUALITY SCALING - L3 -
HIGH QUALITY SCALING - L4 -
HIGH QUALITY SCALING - L5 -
HIGH QUALITY SCALING - L6 -
HIGH QUALITY SCALING - L7 -
HIGH QUALITY SCALING - L8 -
HIGH QUALITY SCALING - L9 -
parameter name sup min max
VIDEO_SURFACE_WIDTH y 48 2048
VIDEO_SURFACE_HEIGHT y 48 1152
CHROMA_TYPE y
LAYERS y 0 4
attribute name sup min max
BACKGROUND_COLOR y
CSC_MATRIX y
NOISE_REDUCTION_LEVEL y 0.00 1.00
SHARPNESS_LEVEL y -1.00 1.00
LUMA_KEY_MIN_LUMA y
LUMA_KEY_MAX_LUMA y
Use xrandr to enable Overscan or better use your TV remote control and set it to Fit or Just Scan Mode, which I would prefer.
For those with 24p Audio drops when Adjust Refreshrate to match Video is turned on, please try those kernels:
wget https://dl.dropboxusercontent.com/u/55728161/linux-headers-3.12.0-rc7ckfixes%2B_1.4_amd64.deb https://dl.dropboxusercontent.com/u/55728161/linux-image-3.12.0-rc7ckfixes%2B_1.4_amd64.deb
sudo dpkg -i *rc7ckfixes*deb
To test, turn on "Adjust Refreshrate to match video" and "Sync Playback to Display" Video Clock (Drop / Dupe) and play some passthrough (DTS, AC3, DTS-HD, TrueHD) at 24p mode.
These won't fix the flickering reported for some asics.
Hi Fritsch,
Can you tell me the latest update (3.12-rc7+) including your 24P Audio drop patch will be included in one of the OpenELEC generic nightly builds?
I would very much like to try it on my Zotac AD06 (E2-1800).
Thanks in advance.
Regards,
Fremske
See latest commit on OE github. It was no new patch. It was a revert.
wsnipex, not sure what you did, but streams are working again from addons.
thanks!
(2013-11-01, 10:49)fritsch Wrote: [ -> ]For those with 24p Audio drops when Adjust Refreshrate to match Video is turned on, please try those kernels:
-snio
Hi fritsch,
I would appreciate a link to the applied patch(es). As a non Ubuntu user this would be really helpful, in order to test with my own kernel build.
Thank in advance.
Regards
They are all listed in the howto thread.
But - some did not work as expected - use latest kernel git and only apply:
Anssi hda radeon patch:
http://onse.fi/files/atihdmi5.patch
If you need some ELD information, you even have to revert two patches in kernel, cause those cause "the flickering" one user reports here.
