Upgraded, no livetv now...
Quote: ERROR: PVR - Add-on 'Tvheadend HTSP Client' is using an incompatible GUI API version. XBMC minimum GUI API version = '5.0.1', add-on GUI API version '1.0.0'
22:36:26 T:140675202934528 WARNING: UpdateAndInitialiseClients - failed to create add-on Tvheadend HTSP Client, status = 6
22:36:26 T:140675202934528 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on Tvheadend HTSP Client, disabling it
(2013-11-14, 18:51)thug Wrote: [ -> ]Upgraded, no livetv now...
I had real trouble getting the cmyth pvr addon working. In the end I rolled xbmc and xbmc-bin back to 2:13.0~git20131111.0500-057e39a-0saucy and built the pvr addons from fetzerch's master branch (
https://github.com/fetzerch/xbmc-pvr-add...master.zip).
This combo seems to be working ok.
@all,
regarding: mini iso
Is it necessary to use the mini-iso for installing Ubuntu 13.10 (as recommended in the how-to)?
I had used the normal Ubuntu 13.10 desktop DVD for installation.
btw.: the Ubuntu 13.10 desktop DVD has no problem with the keyboard.
@ixbeemce: I need the Output of /usr/lib/xbmc/xbmc-xrandr
Concerning Ubuntu: xbmc has a problem with two things a) Unity b) pulseaudio - the rest does not matter. If you can cope with those two - you are fine.
Not sure, just start xbmc from the login manager and test.
(2013-11-14, 19:24)ixbeemce Wrote: [ -> ]@fritsch
regarding surge in 24fps H264 files:
I switch off Compiz, but the surge is still in. It appears about every 5 seconds but only in 24fps H264 files, not in 25fps or 50fps H264 files.
Is somthing wrong with my configuration, or do other testers see similar effects?
for your information :
xbmc@htpc:~$ dmesg | pastebinit
http://paste.ubuntu.com/6416683/
xbmc@htpc:~$ cat ~/.xbmc/temp/xbmc.log | pastebinit
http://paste.ubuntu.com/6416684/
xbmc@htpc:~$ cat /var/log/Xorg.0.log | pastebinit
http://paste.ubuntu.com/6416685/
xbmc@htpc:~$ DISPLAY=:0 vdpauinfo | pastebinit
http://paste.ubuntu.com/6416686/
xbmc@htpc:~$ dpkg -l |grep mesa | pastebinit
http://paste.ubuntu.com/6416687/
Actually, I believe I'm seeing an effect like this also. Noticed it watching a 24fps movie last night - the credits scrolled smoothly for a bit, then judder, then smooth... Will do some more checking.
I'm also seeing a quit to desktop after a movie finishes (only sometimes) although getting the GPU lockups on MPEG-2 content fixed is more pressing at the moment!
You have an A10. That one should not have mpeg-2 lockups at all. But it is quite brand new hardware.
Mind doing a qvdpautest? Something looks really odd here, when I see all that drops.
fritsch and all
One further point regarding the surge/judder problem with 24fps-movies:
I had made also tests where I switch-off the VDPAU in the system settings, the CPU load increases but the surge/judder problem was still in. So I think it is indenedent from VDPAU.
Please update your xbmc package to latest version. Your's is more than 10 days old. Make sure to use the repo we suggest.
@libgradev:
Quote:[ 544.052315] radeon 0000:01:00.0: GPU lockup CP stall for more than 3000msec
[ 544.052322] radeon 0000:01:00.0: GPU lockup (waiting for 0x0000000000006b27 last fence id 0x0000000000006b24)
[ 544.052325] [drm:r600_ib_test] *ERROR* radeon: fence wait failed (-35).
[ 544.052330] [drm:radeon_ib_ring_tests] *ERROR* radeon: failed testing IB on GFX ring (-35).
[ 544.052333] radeon 0000:01:00.0: ib ring test failed (-35).
[ 544.254978] radeon 0000:01:00.0: GPU softreset: 0x00000008
[ 544.254984] radeon 0000:01:00.0: GRBM_STATUS = 0xA0003828
[ 544.254988] radeon 0000:01:00.0: GRBM_STATUS_SE0 = 0x00000007
[ 544.254991] radeon 0000:01:00.0: GRBM_STATUS_SE1 = 0x00000007
[ 544.254994] radeon 0000:01:00.0: SRBM_STATUS = 0x200000C0
[ 544.255063] radeon 0000:01:00.0: SRBM_STATUS2 = 0x00000000
[ 544.255066] radeon 0000:01:00.0: R_008674_CP_STALLED_STAT1 = 0x00000000
[ 544.255069] radeon 0000:01:00.0: R_008678_CP_STALLED_STAT2 = 0x00010000
[ 544.255072] radeon 0000:01:00.0: R_00867C_CP_BUSY_STAT = 0x00000006
[ 544.255075] radeon 0000:01:00.0: R_008680_CP_STAT = 0x80098647
[ 544.255079] radeon 0000:01:00.0: R_00D034_DMA_STATUS_REG = 0x44C83D57
[ 544.255082] radeon 0000:01:00.0: R_00D834_DMA_STATUS_REG = 0x44C83D57
[ 544.255091] radeon 0000:01:00.0: VM_CONTEXT0_PROTECTION_FAULT_ADDR 0x00000000
[ 544.255093] radeon 0000:01:00.0: VM_CONTEXT0_PROTECTION_FAULT_STATUS 0x00000000
[ 544.255096] radeon 0000:01:00.0: VM_CONTEXT1_PROTECTION_FAULT_ADDR 0x00000000
[ 544.255099] radeon 0000:01:00.0: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x00000000
[ 544.255261] radeon 0000:01:00.0: GRBM_SOFT_RESET=0x00004001
[ 544.255315] radeon 0000:01:00.0: SRBM_SOFT_RESET=0x00000100
[ 544.256462] radeon 0000:01:00.0: GRBM_STATUS = 0x00003828
[ 544.256465] radeon 0000:01:00.0: GRBM_STATUS_SE0 = 0x00000007
[ 544.256468] radeon 0000:01:00.0: GRBM_STATUS_SE1 = 0x00000007
[ 544.256470] radeon 0000:01:00.0: SRBM_STATUS = 0x200000C0
[ 544.256539] radeon 0000:01:00.0: SRBM_STATUS2 = 0x00000000
[ 544.256541] radeon 0000:01:00.0: R_008674_CP_STALLED_STAT1 = 0x00000000
[ 544.256544] radeon 0000:01:00.0: R_008678_CP_STALLED_STAT2 = 0x00000000
[ 544.256547] radeon 0000:01:00.0: R_00867C_CP_BUSY_STAT = 0x00000000
[ 544.256550] radeon 0000:01:00.0: R_008680_CP_STAT = 0x00000000
[ 544.256552] radeon 0000:01:00.0: R_00D034_DMA_STATUS_REG = 0x44C83D57
[ 544.256555] radeon 0000:01:00.0: R_00D834_DMA_STATUS_REG = 0x44C83D57
That's a bug for freedesktop.org
fritsch
I have update xbmc to version: 2:13.0~git20131115.05
but the surge/judder problem with 24fps-movies still exist.
@libgradev: good to hear, that I'm not the only one
No idea. Perhaps someone reads this and tells "me too" :-)
