(2013-11-20, 18:54)fritsch Wrote: [ -> ]Yours:
Daemon:
daemon-version: 0.9.22
can-suspend: no
can-hibernate: no
on-battery: no
on-low-battery: no
lid-is-closed: no
lid-is-present: no
is-docked: no
mine:
Daemon:
can-suspend: yes
can-hibernate: yes
on-battery: no
on-low-battery: no
lid-is-closed: no
lid-is-present: no
is-docked: no
You see the difference? -> recheck your polkit stuff. Post those two files.
Yes, I see the difference. Here my custom-actions.pkla file
http://pastebin.com/tskPKFSz
"Post those two files." Witch is the second?
How can I switch can-suspend to yes?
(2013-11-20, 19:33)fritsch Wrote: [ -> ]Code:
dpkg -l |grep linux |grep image
should tell:
Quote:ii linux-image-3.12.0+ 4.0 amd64 Linux kernel binary image for version 3.12.0+
Ok, then I've already got the mentioned kernel.
Play something local, please. To rule out upnp errors.
fritsch I can confirm the consolekit pkg add exposed more proper options in the shutdown. I would have figured it would have been a dependencies in the list of packages installed but I guess so, sorry for the issue just never had the problem since I merely shutdown.
Jep, it was a dependency on Raring, therefore not needed separately. I added it.
(2013-11-20, 21:32)fritsch Wrote: [ -> ]Play something local, please. To rule out upnp errors.
Local files freeze even quicker, no way to grab the debug logs.
But if you like i'll try to grab before...
No idea - the logfile ends unexpected :-)
and freeze is always bad. Remove the radeon.dpm=1 make some memtest.
Concerning the suspend issue: I could not find out what is wrong on one of the affected systems.
If somebody else has ideas, feel free to help. I will ignore suspend / polkit / dbus / upower / udisks question from now on.
That ***** ff******ing complicated system is going on my nerves.
Quote:Thanks to fritsch and ansii I finally know that the Samsung Devices only supports Dolby TrueHD and DTS-HD only with blu-ray playback. The EDID from the HDMI-IN of the Samsung HTD5550 shows that it only accepts DTS and AC3 as input Audio.
How did you get the EDID info? I would like to check my Samsung player as well. Thanks
(2013-11-20, 16:57)fritsch Wrote: [ -> ]Replace this xbmc with xbmc unstable and report back if this is working. Those: https://launchpad.net/~team-xbmc/+archive/xbmc-nightly
The cmyth pvr plays fine with team-xbmc nightly
here's something important: reverted back to xbmc-fernetmenta-master, and if I turn off vdpau, cmyth pvr plays fine (wish I had tried that first)
is there anything I can do to help diagnose why vdpau doesn't work with cmyth?
Does vdpau work with xbmc-nightly?
Provide logfiles with both versions.
Good afternoon. Tell me please. I tried to install XBMC for instructions(step-by-step). DTS-MA does not work(silence) and have dropped frames any video. Maybe I need to make any additional settings?
AMD E1-2100(Kabini) with Radeon HD 8210(m/b - ECS KBN-I/2100)
Post the logfiles from first page.
Kabini is heavy, heavy work in progress.
