Full Version: Sets Manager
first of all: it's really awesome that emm found a new home !!! and is back to life SmileSmileSmile
Thank you very much....
Trying to move everything from my old ember (1.2.2385) to the newest version I have some questions:
Is it possible to "just" take/transfer the folder location names to the new emm ?? (I have so many Sad)
And:
Opening the new sets manager seems to read all movies, but ends in an empty window SadSad
Any chance this can be fixed ??
Added two movie-nfo-files (a set) and the old and new set-manager screenshot-jpgs in a zipped file:
File
Thanks for help !
You can't use the old settings and database, you need a fresh installation. But Ember read all existing NFO and images, if you use the same file settings.
The problem with your sets is that you use a YAMJ setting:
<sets>
<set order="1">1900 SET</set>
</sets>
and not the XBMC setting:
<set>1900 SET</set>.
Do you use XBMC or YAMJ as a Media Center?
btw: German support: Link
Thanks for your immediate response !
I use YAMJ.
Anywhere I can change a setting, that EMM reads my sets ??
(Hope, don't want to have to add them manually Smile
Yep, activate the YAMJ module in "settings -> modules". There you will find the settings for the sets.
Remove all movies before and update the database again after change settings.
Thanks a lot, worked !
Thread can be closed Smile
CLOSED
