14.01.2020 - Version 3.1.2
x reverted usage of NativeFileDialogs for macOS users #762 #764
x fixed some issues in the file-/folder dialogs
x fixed migration of movies from 3.0.x to 3.1.x style
x fixed language detection
19.02.2020 - Version 3.1.3
+ clean empty subfolders after renaming movies/TV shows
+ added "remove artwork" for TV show seasons too
+ (Movie) added a new export template: MoviePicker (thx @bastienpruvost) #763
+ (TV show) added filter for aired status #783
+ updated JMTE to 6.0.0 (IF tokens can now compare to another properties)
+ (movie/TV show) added and option to specify which date should be written into the dateadded field in the NFO #796
+ display file creation/modification date in the media files table
x migrate existing movie set TMDB ids to the new form
x do an artwork cleanup when changing the movie set name
x do not count missing episodes several calculations #769
x (TV show) moved name setting for special season to the image setting panel #775
x (TV show) removed duplicate hotkey
x (IMDB) enhanced parsing of release dates #777
x (YouTube) fixed extraction of newer YouTube trailers
x (TV show) fixed filtering for video format
x better scrolling in the renamer settings
x (IMDB) do not lock the UI if there are no episodes on IMDB #785
x cleanup of artwork when removing movie sets #789
x (TV show) fixed display of artwork size for season artwork #793
x (Trakt.tv) better test routine to show if the connection works
x remember last used folder when choosing files #791
x (TV show) only offer artwork types in the "Download missing artwork" dialog #795
x preserve file creation/modification date on renaming
x (movie/TV show) try to preserve existing IDs when re-scraping with a different scraper
08.03.2020 - Version 3.1.4
+ added some more scraper languages #800
+ added a filter for common audio channel setups
+ (movie/TV show) option to extract artwork from VSMETA on "update data sources"
+ (movie) added an M3U export template (thx @maricn)
+ (movie) added column for sort title
x (TVDB) fixed artwork scraping due to recently changed artwork url
x (TV show) storing duplicate episodes filter
x (movie/TV show) pre-set all artwork/trailer/subtitle scrapers on first start
x (Trakt.tv) do not pass language to the search engine of Trakt.tv to improve the search result
x (TV show) set TVDB id as default in NFO #810
x (movies) removed storing of sort order (because we can not store it completely)
x evaluate movie extras even deeper
20.04.2020 - Version 3.1.5
+ splitted space substitution in the TV show renamer into setting for TV show/season folder and episode filename (thx @dimitricappelle)
NOTE: you may have to review your renamer settings if you used space substitution in the TV show renamer
+ updated libmediainfo to 20.03
+ re-layouted information panels for better visibility on low resolution devices
+ preserve original file name in NFO (movie / tvshow)
+ added support CMYK JPEGs
+ remember last used rating id in the rating editor #788
+ show video bit depth and hdr format in the media files tab and in the editors
+ added Trakt.tv id (movies) and TMDB id (TV shows) with links to the UI
+ enabled scraping of tags from AniDB #836
+ make the scraped amount of keywords in IMDB and tags in AniDB configurable
+ added Kodi RPC call to clean video/audio libraries (thx @max3163)
x (TVDB) catch even more connection problems #832
x show medium dateformat and added date / time format in default Locale
x store user notes in the NFO files
x (TV show) catch occasional errors in NFO parsing #837
x fixed calculation for file size in the renamer #843
x fixed extracting of VSMETA artwork for some movies #760
x fixed displaying of downloaded trailer #838
x (AniDB) fixed reading of specials #827
x Fix localization of Kodi plugins #848
x do not generate trailing separators (space . - _) into subfolder names #853
x enable UPPER, lower and Title renderer on all fields in the renamer
31.05.2020 - Version 3.1.6
+ Further improve episode detection #824
+ added (internal) subtitle language information to the renamer tokens #855
+ added support for double digit stacking patterns (cd12, part12, ..)
+ (movie/TV show) better support for filtering movies by text (regular search, normalized search)
+ added zh_CN and zh_HK to scraper languages #885
x fixed writing of multiple tags (date_added and user_note) in the NFO file
x changed video codec HEVC/x265 to the more common name h265
x fixed occasional UI glitches where artwork did not change
x fixed occasional error messages when removing movies #857
x fixed TMDB fallbackLanguages parsing #861
x (movie) only provide ascending and descending sort order of table columns
x (movie/TV show) provide tags (in dropdown lists) in a sorted order
x (movie) do not move movie extras out of the "Extra(s)" folder upon renaming
x force closing of files after subtitle hash calculation
x (windows) call the default file manager rather than explorer.exe for opening folders
x do not automatically scroll down in the image chooser
x catch occasional hiccups in the trailer panel #864
x fixed layout of the movie settings panel
x fixed rescaling of the tasklist #892
x fixed special handling of discart with multi movie folders/disc images
29.06.2020 - Version 3.1.7
+ (movie) only show used genres in the genre filter
+ added fr_CA to scraper languages
x fixed detection of multipart files
x fixed displaying of h265/hevc logo
x fixed writing of h265/hevc to the NFO file
x improved handshake with opensubtitles
x (tmdb) stricter fallback language detection #897
x fixed deleting search results where title AND year are the same but the movie is different
01.09.2020 - Version 3.1.8
+ updated libmediainfo to 20.08
+ updated Movie Picker template (thx @bastienpruvost)
x removed a memory leak in IMDB scraper
x do not write fanarts twice in multi movie folders #956
x fixate artwork extension if not detectable #953
x propagate mediainformation events from episode to TV show
x write cleaner trailer urls to the Kodi NFO
x more aggressive caching of AniDB requests
x set character and path encoding at startup #930
x do not open two windows when clicking on a link
x do not crash at startup with an inconsistent movie set <-> linkage
x (tv show) added some missing menu items to the context menu #934
x (movie) pre-select the right NFO file names in the NFO settings panel
x save scraper config in the custom data folder too #962
x (imdb) fixed to scrape shows without season 1
x (omdb) set IMDB id when scraping with OMDb API
18.09.2020 - Version 3.1.9
x removed kyradb.com artwork provider
x take the correct artwork extension when using local files in the image chooser
x several enhancements to the AniDB scraper
30.09.2020 - Release 4.0
- bundled JRE and rewritten launcher (no installed Java needed any more)
- real HiDPI support (slightly changed look and feel to achieve correct UI scaling)
- mix in IMDB ratings for almost every scraper without the need of the universal scrapers
- universal TV show scraper
- completely reworked libmediainfo usage:
- full support of reading/writing mediainfo XML files
- better support of disc structures (.iso and VIDEO_TS/BDMV/HVDVD_TS folders)
- several fixes for reading data out of libmediainfo
- enhanced filter management
- new command line interface
- mediainfo integration for Trakt.tv
- support for Windows taskbar / macOS dock access
- added a true regular expression search for movies/movie set/TV show titles
- display missing episodes in the season overview panel
- provide artwork from TMDB for Trakt.tv search
- added showlink support for movies
- better performance in regular expression searches
- fixed handling of MP2/MP3 streams
- enhanced downloading of youtube trailers
- KodiRPC: improve matching
- and many more changes under the hood...
30.09.2020 - Release 4.0.1
x fixed upgrade of v3 settings
30.09.2020 - Release 4.0.2
+ enhanced display of ratings
+ added action to re-fetch IMDB ratings #989
x set "Disable SSL certificate verification" to true per default to avoid connection problems
x cleanup of changed artwork extensions #1015
x show language names in UI language #1010
x added more rating providers to the settings
x re-added file size to the media files table
x preserve epbookmark tag in episode NFOs
x reworked the new indicator to use less space
x rebuild image cache when changing data source #1021
x writing/cleanup of downloaded subtitle files #993
04.10.2020 - Version 4.0.3
+ added a year column in the TV show tree #1026
+ added a release date column in the movie table #1029
x do not cleanup episodes if the TV show has not been loaded
x several fixes for the universal TV show scraper #1024
x added second runtime column
x better movie detection when having them in 'reserved names' folders
x also respect current file names in the file name filter #1007
x show original image in original size #992
x several fixes to the command line interface
x universal TV show scraper uses less memory now
Version 3.1.10
+ added a file size renderer to the export templates
x added some changes to improve youtube trailer downloading
x included a search rate throttling for opensubtitles #988
x KodiRPC uri matching
x preserve epbookmark in episode NFOs
x (tvdb) also show the artwork on a second search
07.10.2020 - Version 4.0.4
+ added setting to suppress writing of <episodeguide> tag
x (image chooser) show original image always in original size
x errors when downloading images #1039
x (TV show) write trailer urls in Kodi compatible format into NFO #1040
x proper update of vote count for ratings
x fixed writing of the .desktop files in linux
x fixed restart of tinyMediaManager after upgrade to v4
Version 4.0.5
+ added support for trailer download to /trailers #787
+ re-added tinyMediaManagerCMD.exe for Windows command line execution
+ added subtitle count filter for TV shows
+ updated libmediainfo to 20.09
x fixed reading hybrid DVD ISOs
x completely reworked trailer downloading to fix several issues #1060
x reworked aspect ratio calculation
x lowered memory consumption of the imdb rating fetching
x draw table/tree grid when multiple rows are selected
x improved loading time of large libraries
x more precise search results when searching for text only
x added an option to specify which actors should be fetched from IMDB #1062
x updated live calculation of movie set/movie count #1064
x inversion of media file filter for TV shows #1063
x prevent trailer from being renamed from within /trailer(s) folder
x support reading of the mediainfo.xml for unsupported files (.disc, .img, ...)
x fixed reading of mediainfo via UNC paths #1071
x fixed some updater issues
x fixed macOS dock pin issue
x MPAA tag in the NFO now also respects the certification style setting
