2013-10-06, 13:39
Hi XBMC Forum
I've got a Philips 58pfl9956 21:9 tv.
I've chosen a resolution of 1920x810, since the tv can't accept 2560x1080 natively. 1920x1080, when zoomed, hides some of the top/bottom menu's unless I change aspect ratio on the TV, every time I want to ex. add subtitles etc. So it's comfort over picture quality. I might go 1920x1080 again, but I need to solve this problem before I go mad.
Nvidia setup: Resize option 1080, 1920x810 (shows a 16:9 with a black bared 21:9 image)
TV setup: Cinema 21:9 (zooms the black bared 16:9 image to the edges)
XBMC skin: Aeon Nox (frodo 12.2)
Problem:
Settings -> System -> Video output -> Video calibration. After adjusting the edges/subtitles I try to adjust the square. The square is default at (1000) Pixel ratio, but when I adjust, it immediately jumps to (0.844). I can't go any higher than that. As a result, the movies are slightly stretched horizontally. The only way to get it back, is going to app data and delete guisettings.xml and that's losing its charm after a few tries. I could leave the square at (1000) but it's not perfectly squared, and that's bothering me.
Edit: Or in other words... can't adjust the square vertically.
I love to sit for hours and just read until I figure it out, with the help of the excellent posts here, but I must admit defeat and ask for help.
I hope I've provided enough information.
Problem:
