Full Version: Scanned music not appearing in library.
I've done a bunch of searching and a bunch of library resetting with no success.
-All files are properly tagged.
-I can scan them in, the little popup on the top will come up and go through each directory.
-I can look at the music database and see that everything is in there.
When I go to use library mode though, it is just empty. No idea what to do anymore.
http://xbmclogs.com/show.php?id=66840
The selected items are what was added to the library with this debug log.
http://imgur.com/nLzlS38
Any help would be great.
Shameless self-bump
Seems like a mysql problem somewhere, Looking at the log i see, Xbmc didn't create some tables. "ERROR: SQL: The table does not exist"
I'd suggest you drop the db & start again, Make sure the xbmc user has grant all privileges.
http://wiki.xbmc.org/index.php?title=HOW...g_up_MySQL
What version of mysql are you running? XBMC only works with MySQL 5.5 and lower.
http://wiki.xbmc.org/index.php?title=Tal..._databases
(2013-10-10, 22:13)mdleal82 Wrote: [ -> ]What version of mysql are you running? XBMC only works with MySQL 5.5 and lower.
Yeah, noticed that when I checked the page. Downgrading to 5.5 fixed the issue.
