2013-10-07, 23:16
I am a newbie and trying to builf the xbmc on android.
I am using:
android-ndk-r8-crystax-1-linux-x86_64.tar.bz2
xbmc-12.2.tar.gz
and the latest android sdk
I followed the readme instructions to the T with a configure of:
./configure --with-ndk=/home/jerry/crystax_android_ndk/android-ndk-r8-crystax-1 --with-sdk=/home/jerry/Desktop/adt-bundle-linux-x86_64-20130729/sdk --with-toolchain=/home/jerry/crystax_android_ndk/android-9 --with-tarballs=/home/jerry/xbmc-tarballs --prefix=/home/jerry/Desktop/xbmc-12.2/tools/android/depends --host=arm-linux-androideabi
And I get to the point where I build from the xbmc directory (make -C tools/android/depends/xbmc).
I get an error concerning boost
| #define HAVE_STRTOL 1
| #define HAVE_STRTOUL 1
| #define HAVE_SYSINFO 1
| #define HAVE_TZSET 1
| #define HAVE_UTIME 1
| #define SIZEOF_INT 4
| #define SIZEOF_SIZE_T 4
| #define HAS_BUILTIN_SYNC_ADD_AND_FETCH 1
| #define HAS_BUILTIN_SYNC_SUB_AND_FETCH 1
| #define HAS_BUILTIN_SYNC_VAL_COMPARE_AND_SWAP 1
| #define SIZEOF_WCHAR_T 4
| #define HAVE_INOTIFY 1
| /* end confdefs.h. */
| #include <boost/shared_ptr.hpp>
configure:20384: result: no
configure:20384: checking for boost/shared_ptr.hpp
configure:20388: error: Could not find a required library. Please see the README for your platform.
do you know why this is happening?
I am using:
xbmc-12.2.tar.gz
