2013-10-08, 02:44
I am using a third party program, Media Companion, to automatically download all the trailers for my library. They are named in this format <move>-trailer.ext. I would say about 25% of my trailers won't play. XBMC detects that there is a trailer available to play but every time I hit the 'play trailer' button nothing happens.
There is no correlation with file type or anything like that. When I go to 'show information' and then hit 'refresh/reload,' the trailer for that particular movie will then start working as it should. I could manually reload/refresh all affected movies but that would just be too time consuming.... In the past when I needed to refresh or reload many movies I would just set my folder content to 'none' and then set it back to 'movies' again to let XBMC reload my entire library. This doesn't seem to work for this situation however...every time I try to reload my entire library the same exact trailers don't work again and I have to go back and manually reload them. Any thoughts?
