2013-10-09, 00:29
Hello!
I'm working with a fresh install of a rooted MK809 Android MiniPC running Finless 1.7 and the latest stable Frodo release of XBMC, plugged into a Hitachi 42" 1920x1080 plasma TV. All of XBMC runs well until I attempt to play a karaoke song (mp3+cdg), at which point the karaoke text displays at what appears to be the wrong resolution. Essentially, only the "Upper Left" portion of the words appear on screen. To illustrate, here are some pictures:
shows my Karaoke settings
shows the opening screen, where you can see that the bulk of the words are not on screen.
shows the lyrics during play. Again, the screen only displays part of the lyrics.
To summarize, it seems like the resolution for the lyrics isn't set to 1920x1080. The size and style is not affected by the settings under karaoke, most likely because .cdg files are self-contained binaries that can display any image and text that they want; they don't rely on the underlying player to be displayed.
Here's a test song to use (Counting Crows' "Daylight Fading) and its companion .cdg file:
http://www.mediafire.com/?5dggrjw0x8tlfaa
http://www.mediafire.com/?eukc4kkdvydbbyj
Please let me know if there's anything else I can supply to assist with this, and thank you so much for helping me out!
