I came across the wonderful Artwork downloader, which seems to have filled in most of the gaps I had in my various sections. After having finished all the relevant
scans I read that by default all artwork is downloaded to the cache folder and not to the movie or TV directory, is this true?
Will the Artwork organiser that I've discovered grab all this artwork and put it into the relevant folders?
Or should I stop worrying and just leave things how they are?
or you can use Ember Media Manager to have relatively full control over your images. if you're happy with the images, just leave them alone. I recommend using EMM though
Go to settings and use the 'Use local files' option
Thank you guys for the help.
I wanted to be certain of a few things and I guess I'm being a bit anal in wanting everything all in one place.
I didn't have use local files selected when I did the initial scan so the artwork is in some folder in the xbmc directory I assume. Most of my artwork was already grabbed by MCM and in the local folders. I assume if you select use local folders before the initial scan then it will make the whole scan very quick because I have most of the artwork already, but as it is I didn't do this so I assume I have all the covers etc doubled up somewhere?
What happens if you select centralise extrafanart before/after the initial scan?
I guess if I leave everything how it is I'd like to know where the Artwork downloader puts all it files so I can access them. Ideally I'd like to have all downloaded files in my local folders for backup reasons, but like I said I guess I',m being a bit anal because everything is working, but I do like to get a handle on things, which I seem to be failing to do here
hi everybody
i want to ask bit more about it,
i am using EMM and its amazing but it doesnt download all the artwork like discart and clearart. is there anyway that after i put all movie in his folder and scrapewith EMM, i can run artworkdownloader and make it put all the rest of the stuff that i mention in each movie folder?
and if not where can i find all the discart clearart and etc.?
thanks
