Noting of note: 15:21:56 to 15:22:03 or 5 seconds.. would be a bit faster if there was .nfo files for these and didn't have to exit to search DEBUG: scraper: CreateSearchUrl returned <url>http://api.themoviedb.org/3/search I would suggest you change to the universal scraper and use the IMDB option and manually scrape these listings.
WARNING: No information found for item 'C:\Movies\Cashback (2007)\Cashback (2004).avi'
No NFO file found. Using title search for 'C:\Movies\Cashback (2007)\Cashback
No information found for item 'C:\Movies\Alpha Dog (2006)\Alpha Dog (2006).avi', it won't be added to the library.
No NFO file found. Using title search for 'C:\Movies\CKY Documentary (2001)\CKY Documentary (2001).avi'
No NFO file found. Using title search for 'C:\Movies\Insomniac with Dave Attell (2003)\Insomniac with Dave Attell (2001).avi'
No NFO file found. Using title search for 'C:\Movies\Jay and Silent Bob Get Old - LIVE!!\Jay.and.Silent.Bob.Get.Old.2012.avi'
No NFO file found. Using title search for 'C:\Movies\My Sassy Girl (KOREAN)\My Sassy Girl (2008).iso'
No NFO file found. Using title search for 'C:\Movies\Sid and Nancy (1987)\Sid And Nancy (TUS Release).bin'
No NFO file found. Using title search for 'C:\Movies\Solitary Man (2009)\Solitary Man (2009).avi'
No NFO file found. Using title search for 'C:\Movies\Stranger Than Fiction (2005)\Stranger than fiction (2005).avi'
No NFO file found. Using title search for 'C:\Movies\The Best Exotic Marigold Hotel (2011)\The Best Exotic Marigold Hotel (2011).avi'
No NFO file found. Using title search for 'C:\Movies\The Transformers (2007)\Transformers (2007).avi'
15:22:03 to 15:22:10 for some sort of audio initialization.... which takes 7 secs! you might have a look at the thread.
http://forum.xbmc.org/showthread.php?tid=146911 and see if everything looks jake.
These files seem be causing issues... take them out of the database temporarily
WARNING: could not find codec parameters for C:\Movies\American Movie (1999)\American Movie (1999).bin
15:22:10 T:4484 DEBUG: CThumbExtractor:
oWork - trying to extract filestream details from video file C:\Movies\Van Wilder 2, The Rise of Taj (2006)\Van Wilder 2- The Rise of Taj (2006).bin
15:22:10 T:4436 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:13
and it looks like you have a few corrupt graphics...This is taking a lot of time and CPU, You might be better of deleting the thumbnails and let the system rebuild. C:\Users\Andrew\AppData\Roaming\XBMC\userdata\thumbnails You might get a bit of relief turning off scanning on start if you have it on... Settings>videos>library
ERROR: ffmpeg[131C]: [IMGUTILS] Picture size 0x0 is invalid
15:22:10 T:4892 ERROR: ffmpeg[131C]: [bintext] get_buffer() failed
15:22:10 T:4892 DEBUG: ffmpeg[131C]: [bin] decoding for stream 0 failed
ERROR: ffmpeg[1184]: [IMGUTILS] Picture size 1280x41893344 is invalid
15:22:10 T:4484 DEBUG: ffmpeg[1184]: [NULL] ignoring invalid width/height values
Anytime you have the word 'Error' that's enough for XBMC to choke... I suspect this is the real villain ERROR: ffmpeg[13E8]: [IMGUTILS] Picture size 1280x42024112 is invalid, finding it might be a trick. But I'm not sure how XBMC deals with .bin movies (I don't have any).
After you clean up a bit, put this code in your C:\Users\ANDREW\AppData\Roaming\XBMC\userdata\advancedsetting.xml file it will help.
<gui>
<algorithmdirtyregions>1</algorithmdirtyregions>
<nofliptimeout>1000</nofliptimeout>
</gui>
